Furnace - HVAC - DIY Chatroom Home Improvement Forum
Old 10-06-2010, 06:48 PM   #1
furnace
the flame goes around the burner instead of up, what would do this?
needhelp72 is offline   Reply With Quote
Old 10-06-2010, 06:53 PM   #2
Plugged heat exchanger cell or plugged chimney.
Turn off furnace ASAP ...your furnace is producing carbon monoxide
hvaclover is offline   Reply With Quote
Old 10-06-2010, 06:56 PM   #3
how do you unplug the cell?
Old 10-06-2010, 07:01 PM   #4
The cell could be cracked. Is there a lot of rust or soot on the of the top of the burner and underneath it? Are all the burners doing this>
How old is the furnace. Sorry, but important to know.
Old 10-06-2010, 07:17 PM   #5
there is a lot of soot in the one space, the other 2 are working normal. the furance is about 15 years old
Old 10-06-2010, 07:30 PM   #6
ok..not to scare you, but this is a serious problem.
The furnace is old and you have one cell that is burning badly...could be a crack.
Given the age of the furnace i would replace it or change the entire heat exchanger, understand this is the advice I would give you were I checking your furnace in person.
It is important to get a qualified hvac tech to safety check your furnace.
You have a "Red Tag" situation that would force the furnace to be shut off for safety sake.
How the burner got that way is immaterial right now becasue the damage is already done.
I can only help you with the information I have given you.
Call a tech but shut the furnace off ..it is unsafe.
Good Luck
Old 10-06-2010, 07:43 PM   #7
Hvac Pro
yuri's Avatar
Rewards Points: 2,238
Your furnace IS producing carbon monoxide and that is dangerous and deadly. CO is produced by incomplete combustion/mixing of the gas with air and your plugged exchanger is causing that to happen. SHUT it down and call a Pro or the gas co if they have service techs to find out why it is doing that.
Old 10-06-2010, 07:46 PM   #8
Must be an echo in here
Old 10-06-2010, 07:51 PM   #9
Hvac Pro
yuri's Avatar
Remember the guy last yr who would not believe us? Said he was used to the smell of CO as he breathed it in all the time in his garage. Did not believe in CO detectors. Just want to make sure the OP takes it seriously and not trying to save a buck and let it go.
Old 10-06-2010, 07:56 PM   #10
That guy turned out to be one of the pros who hangs out an another site. He comes here all the time impersonating home owners.
But yeah, I do agree two opinions are better than one
Old 10-06-2010, 08:07 PM   #11
Hvac Pro
yuri's Avatar
Maybe a bit "brain damaged" from breathing in the ole CO gases.
Old 10-06-2010, 08:12 PM   #12
He has posted how much he hates what we pros do here...
Old 10-06-2010, 08:27 PM   #13
Hvac Pro
yuri's Avatar
Thats too bad. I am sure we are not stealing his customers.
Old 10-06-2010, 09:22 PM   #14
HVAC / Plumbing
Lack of maintance. At that age that unit should have been check every heat season b-4 use
kenmac is offline   Reply With Quote
Old 10-06-2010, 09:49 PM   #15
lol.. jeeze the guy probably feels bad enough....
The Following User Says Thank You to hvaclover For This Useful Post:
needhelp72 (10-08-2010)
Lennox Furnace G27M Series Unreliable operation: pressure switch or else? sheppard1977 HVAC 7 01-14-2013 05:42 PM
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 03:51 PM
Furnace air filtration advice stephen_smith HVAC 7 12-24-2010 02:24 AM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 01:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
