Furnace - HVAC - DIY Chatroom Home Improvement Forum
Old 01-24-2010, 12:35 PM   #1
Unhappy
furnace
My furnace is mounted under the house that I rent, It is starting to leave black resadue on my walls does anybody know whats wrong?
cueball74 is offline   Reply With Quote
Old 01-24-2010, 12:44 PM   #2
Furnace is leaving black resadue on EVERTHING in my house, but you can't physically see in coming from my vents. Whats wrong??
Old 01-24-2010, 01:04 PM   #3
Licensed Master Plumber
Yea, it's not burning clean. could be a whole bunch of things from simple and inexpensive to complicated and very costly. Call your heating technician. Black soot is bad and could be very harmfull to your health as well.
NHMaster is offline   Reply With Quote
Old 01-24-2010, 01:05 PM   #4
as seen on tv
Rewards Points: 150
You should have that checked by pro, It may be soot a byproduct of improper combustion
qbert is offline   Reply With Quote
Old 01-24-2010, 01:18 PM   #5
Hvac Pro
yuri's Avatar
Rewards Points: 396
Buy a CO detector and call your gas utility (if it is gas) and see if they can come over for free and test for CO in your house. Some utilities will do that for free. Get the landlord to have it properly checked by a Pro and phone the rentalsman/housing authority if he refuses. Oil can produce CO also.
Old 01-24-2010, 02:20 PM   #6
JohnH1's Avatar
Do you burn candels? The nice smelling ones have a lot of oile in them and produce soot. It only takes one sooty candle to sent soot all over the home.
JohnH1 is offline   Reply With Quote
Lennox Furnace G27M Series Unreliable operation: pressure switch or else? sheppard1977 HVAC 7 01-14-2013 05:42 PM
Furnace air filtration advice stephen_smith HVAC 7 12-24-2010 02:24 AM
Oil furnace does not fire up sbhavinm HVAC 5 01-17-2009 07:06 AM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 01:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
