Furnace- - HVAC - DIY Chatroom Home Improvement Forum
Old 10-24-2009, 04:44 PM   #1
Furnace-
House inspector says there may be a crack in my furnace combustion chamber and that if there is the furnace will have to be replaced. How does a contractor check if the chamber is cracked. Are there any alternatives to replacing the whole furnace?
Cornell
cornell is offline   Reply With Quote
Old 10-24-2009, 10:05 PM   #2
30 year tech
hvac122's Avatar
It depends on what kind of furnace you have as to how it will be checked for a cracked chamber.
Depending on the age of the furnace there may be a replacement heat exchanger availiable. If you are the one that is going to live there I would upgrade to a more efficient furnace. Make sure the contractor figures out what happened to the old chamber if cracked so it dosn't happen again.
hvac122 is offline   Reply With Quote
Old 10-24-2009, 10:13 PM   #3
Thank you. Cornell
Lennox Furnace G27M Series Unreliable operation: pressure switch or else? sheppard1977 HVAC 7 01-14-2013 05:42 PM
Furnace air filtration advice stephen_smith HVAC 7 12-24-2010 02:24 AM
Oil furnace does not fire up sbhavinm HVAC 5 01-17-2009 07:06 AM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 01:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
