Furnace - HVAC - DIY Chatroom Home Improvement Forum
Old 09-18-2009, 01:04 PM   #1
furnace
Can you ruin a furnace by turning it off while it is running?
angmgard is offline   Reply With Quote
Old 09-18-2009, 02:05 PM   #2
DIY = Done Right 1st Time
No. Turn it off when you want to.
BowDown is offline   Reply With Quote
Old 09-18-2009, 02:54 PM   #3
30 year tech
hvac122's Avatar
If you mean turning it off with the thermostat then no. If you mean turning off the power while its running then possibly. The blower is designed to run after the burners shut off to remove most of the heat from the heat exchanger. If you shut the power off all the time then it could put undue stress on the heat exchanger.
hvac122 is offline   Reply With Quote
Old 09-18-2009, 04:37 PM   #4
An old Tradesmen
Rewards Points: 6,072
Yep, not good for it in the heat mode.
Lennox Furnace G27M Series Unreliable operation: pressure switch or else? sheppard1977 HVAC 7 01-14-2013 06:42 PM
Furnace air filtration advice stephen_smith HVAC 7 12-24-2010 03:24 AM
Oil furnace does not fire up sbhavinm HVAC 5 01-17-2009 08:06 AM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 02:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 02:45 AM
