Furnace - HVAC - DIY Chatroom Home Improvement Forum
Old 04-14-2011, 07:50 PM   #1
furnace
The furnace would not stop running yesterday, so i was told to check the relay. Tap on the relay with a screwdriver or something to loosen it because it maybe sticking. I took the blower out of the furnace, put it back, tapped on the relay and it (the blower) started working. I turned the system on it took a few minutes for the outside system to come on and when it did it soon turned back off and now it want come on again. What do you think the problem is?
edward5 is offline   Reply With Quote
Old 04-15-2011, 04:16 AM   #2
An old Tradesmen
Rewards Points: 7,372
Is this a furnace or a heat pump?
Best to check things with a meter, tapping with a screw driver doesn't tell you much about what is wrong. Unless you know what isn't wrong.
Lennox Furnace G27M Series Unreliable operation: pressure switch or else? sheppard1977 HVAC 7 01-14-2013 05:42 PM
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 03:51 PM
Furnace Model # Feh-015-04 clicking but not turning on? haimei HVAC 1 12-14-2010 05:01 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 01:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
