Furance Room Ventalliation - HVAC - Page 3 - DIY Chatroom Home Improvement Forum
Old 11-11-2008, 12:58 PM   #31
Rewards Points: 518
Furance room ventalliation
Originally Posted by Black Adder View Post
I don't feel that you need to do anything else to the setup you have. If it meets code which it seems to according to your conversation with the inspector. The furnace room is going to get warm with the equipment running, the heat is radiant coming from the chimney and from the furnace body itself. I have never seen a furnace with the outside casing completly insulated so of course when it gets hot it is going to radiate heat. The heat will disipate fairly quickly when the unit goes off.
Yeah, I called him back and he said that my room temps I gave him are just fine and are normal for my setup. Sounds like everything is ok, I just hope there is adequate combustion air. Not sure how to tell if its lacking, maybe when the CO detectors go off in mid winter....
n0c7 is offline   Reply With Quote
Old 11-11-2008, 07:32 PM   #32
Check around the burner opening and the draft hood on the water heater, if it is back drafting you will feel heat rolling out from it. If your furnace is fairly new (last 10 years or so) it will have a draft switch on it. If it starts tripping then you have a draft issue. If not I would say you are good to go. You also have the added safety of the CO detectors.
Black Adder is offline   Reply With Quote
Old 11-11-2008, 07:45 PM   #33
Rewards Points: 518
All seems well. Furnace installed 2004. Mid-efficiency I believe.
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 10:11 PM
Heat pump in non insulated nor heated room robdville HVAC 3 01-21-2008 03:51 PM
Hardwood flooring - 3 walls and a sunken living room basledder Flooring 1 12-09-2007 06:34 PM
Room to Room Vent cjpilot HVAC 5 12-02-2007 09:53 PM
My kids room is cold snmhanson HVAC 5 12-20-2006 12:51 PM
