Furance Blower Loud Noise Just Started - HVAC - DIY Chatroom Home Improvement Forum
Old 10-17-2011, 10:46 PM   #1
furance blower loud noise just started
My furnace is 6 years and old and always was very quiet. In the past 2 months, the blower got very loud and vibrates. If I take it out of the furnance, it runs very quiet on the floor. When I cover half the exhuast area with a board, I can recreate the loud noise and vibration. This occurs at all speeds, low, med or high. My observation is that when the blower has to work hard, it starts to vibrate and make a loud sound.
Is it my blower motor, the fan or do I have a restricted air way? I did all obvious thing, removed the filter, opened all the ducts, cleans the ducts and fan blades etc. It is not obvious to me what I should do next.
Tom Gramc is offline   Reply With Quote
Old 10-17-2011, 10:52 PM   #2
JJboy's Avatar
PSC or ECM motor?
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 10-17-2011, 10:58 PM   #3
Bryant 350MAV system
3/4 HP Motor
14.6A
120VAC
Old 10-17-2011, 11:51 PM   #4
I'm Your Huckleberry
Rewards Points: 2,270
http://www.gogeisel.com/geiselonline..._355MAV_OM.pdf
Does not say what the blower is. Any fault codes?
Doc Holliday is offline   Reply With Quote
Old 10-17-2011, 11:55 PM   #5
no fault codes. The unit is working, just very loud. THe motor is a PSC motor
Old 10-17-2011, 11:56 PM   #6
Sitting here behind my computer I'm going to have to put my money on the bearings on the blower motor are wearing out.
Old 10-18-2011, 12:03 AM   #7
JJboy's Avatar
Yeap, sounds like bearings
Old 10-18-2011, 12:03 AM   #8
The motor date code is Dec 2004. It is coming up on 7 years, it run both AC and Heat year round. Does that sound like the typical life of a blower motor? If so, it would be worth the shot to replace it if it is near the end of life anyhow.
Old 10-18-2011, 12:11 AM   #9
The sound only occurs when in the unit or loaded down. Quiet when running on the floor. ALso, it is not a high pitch screaching sound like bearings. It is more like the fan metal is rubbing on something. Do you still think it could be bearings? Just wanted to bounce that off you before a shop for a motor. Any suggestions motor purchase sites?
Old 10-18-2011, 12:16 AM   #10
Certainly. And since you have a 90% condensing furnace you can always uprgrade that single stage psc motor to an ecm and get quite a bit more efficiency out of it.
Old 10-18-2011, 12:21 AM   #11
Is there a loose screw, possibly causing the housing to vibrate or are there any marks internally on the blower motor housing reminiscent of the blower wheel rubbing on it?
Is there possibly a blade on the wheel broken and hitting the housing, scraping it? A loose weight perhaps, such as on your vehicles rim for tire balancing?
Does the shaft of the motor move in and out at all?
Old 10-18-2011, 12:31 AM   #12
I looked for marks and scratches and could not find any. ( I did not take the housing completely apart, only what I could see) The shaft does not move up or down, but does move in and out a bit ( maybe a 1/8 inch) when I spin the fan with no power, it spins very free and quiet and coast for a few minutes.
Old 10-18-2011, 12:39 AM   #13
Bearings are going bad, the shaft should not move in and out at all. In blower motor shaft movement that 1/8th of an inch might as well be a mile.
In time, shortly I'd have to assume, you will hear the high pitch squealing and scratching an irritating metal on metal of the point of no return bad bearings. What you hear now is just the beginning.
But on the bright side, if you watched that vid I'd be pretty excited if I were in your shoes as now's your chance to really have an awesome, evergy efficient furnace. Granted those motors are not cheap compared to psc but you'll make a return on your investment through your noticabley lowered electrical bill.
The Following User Says Thank You to Doc Holliday For This Useful Post:
Tom Gramc (10-18-2011)
Old 10-18-2011, 12:42 AM   #14
OK, you convinced me. I watched the video, and it does make good sense. I will look into this more tomorrow. Getting late, thank you for your help exchanging ideas.
Old 10-18-2011, 12:49 AM   #15
You're welcome. Let us know what you decide and how it works out for you.
Heat comes on but blower never does aczer HVAC 12 02-13-2011 07:57 AM
Blower motor noise gsracer HVAC 5 11-09-2010 07:05 PM
Furnance blower fan Noise! rosco HVAC 4 12-28-2009 10:03 AM
Loud clank noise on pipes santino94 Plumbing 0 12-27-2009 03:28 PM
Loud humming noise from electric forced air furnace MissBehavin HVAC 9 01-02-2009 06:14 PM
