#1 |
furanace won't kick on automatically
my 22 year old heil furnace will run fine if i manually press the up button on the programable thermostat, but it won't kick on it's own. i replaced the thermostat and it is doing the exact same thing. that makes no sense to me!
#2 |
what brand and model on that new stat
#3 |
Check for a loose wire at the W or R teminal on the furnace.
Baring that you have a bad stat AGAIN, or some issues with the furnace, Is it a standing pilot or an electric ignition.
Just slow, not stupid. |
#4 |
it is an electronic spark ignition
#5 |
the furnace is a HEIL NUGJ100AF02 it was a honeywell stat but i already took it back so i dont know the model number. the furnace is running great as long as i manually hit the up on the stat? any ideas.
#6 | |
furanace won't kick on automaticallyQuote:
Do you mean you increase the temp?
#7 |
the furnace should kick on when the temperature falls 2 degrees below the set temperature, but it can drop 10 degrees below set temperature and it will not kick on until i hit the up teperature on the stat. then it runs perfect and shuts off just like it should. could it be a bad gas valve?
| Display Modes | |
| Goodman Furnace does not kick in | wctoro | HVAC | 2 | 02-20-2008 02:47 PM |
| How to make a "BiFold" door close automatically? | WalksInDarkness | Building & Construction | 8 | 01-23-2008 01:13 PM |
| Oil burner won't kick on, have to push reset | edski | HVAC | 4 | 11-06-2007 03:04 PM |
| Main Fan Won't Kick On | Mavyak | HVAC | 3 | 06-05-2007 11:29 PM |
| Armstrong furnace won't kick on | Kristamarie | HVAC | 5 | 12-06-2006 04:36 PM |
