-   -   furanace won't kick on automatically (http://www.diychatroom.com/f17/furanace-wont-kick-automatically-30230/)
36inchflange 10-19-2008 09:40 PM
my 22 year old heil furnace will run fine if i manually press the up button on the programable thermostat, but it won't kick on it's own. i replaced the thermostat and it is doing the exact same thing. that makes no sense to me!
biggles 10-19-2008 11:28 PM
what brand and model on that new stat
hvaclover 10-19-2008 11:40 PM
Check for a loose wire at the W or R teminal on the furnace.
Baring that you have a bad stat AGAIN, or some issues with the furnace,
Is it a standing pilot or an electric ignition.
36inchflange 10-20-2008 07:56 PM
it is an electronic spark ignition
36inchflange 10-20-2008 08:04 PM
the furnace is a HEIL NUGJ100AF02 it was a honeywell stat but i already took it back so i dont know the model number. the furnace is running great as long as i manually hit the up on the stat? any ideas.
hvaclover 10-20-2008 08:34 PM
I don't follow what you mean by up on the stat.
Do you mean you increase the temp?
36inchflange 10-20-2008 09:44 PM
the furnace should kick on when the temperature falls 2 degrees below the set temperature, but it can drop 10 degrees below set temperature and it will not kick on until i hit the up teperature on the stat. then it runs perfect and shuts off just like it should. could it be a bad gas valve?
hvaclover 10-20-2008 11:15 PM
I'd say there are too many varibles to nail it down with out doing some tests.
