Fujitsuheatpump - HVAC - DIY Chatroom Home Improvement Forum
Old 11-10-2011, 08:18 PM   #1
fujitsuheatpump
Will my fujitsu heat pump work at any outside temp
jimd. is offline   Reply With Quote
Old 11-10-2011, 08:50 PM   #2
Retired from the grind
gregzoll's Avatar
Rewards Points: 5,822
fujitsuheatpump
Usually they stop working as a heat pump around 35 degrees Fahrenheit, then your furnace/aux heat will take over. Depends on how it was set up by the installer.
Ren: Now listen, Cadet. I've got a job for you. See this button? Ren: Don't touch it! It's the History Eraser button, you fool! Stimpy: So what'll happen? Ren: That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you?
Old 11-10-2011, 09:01 PM   #3
fujitsuheatpump
Most fujitsu heat pumps will work down to 5 degrees F.
Master of Cold is offline   Reply With Quote
