Fuel Oil Furnace Problem - Help Needed! - HVAC - DIY Chatroom Home Improvement Forum
Old 12-31-2014, 05:13 PM   #1
Rewards Points: 6
I heat my home with an fuel oil furnace and the problem I'm having is:
The Intermittent Ignition Oil Primary which is a (Honeywell R8184G 4009) is making a loud clicking repetitive noise.
If I push in the red reset button it will work for a few cycles and then start making the clicking noise and kick the reset button out and the red light comes on. If I try to reset immediately it will only continue to make the clicking noise, I have to let it set for awhile before I can reset and the furnace will cycle again.
I have purchased and replaced with a brand new Honeywell R8184G 4009, but I'm still getting the same exact thing happening.
Please help if you know what's causes this... "It's Cold Outside"
Joe1234 is offline   Reply With Quote
Old 12-31-2014, 06:48 PM   #2
Is your cad cell dirty.?
How old is the nozzle ?
What is your oil pressure ?
gassyplumber is offline   Reply With Quote
Old 12-31-2014, 11:19 PM   #3
An old Tradesmen
Rewards Points: 7,802
Sounds like the cad cell or its wires are beginning to short out.
Old 01-01-2015, 12:16 AM   #4
Rewards Points: 6
I will have to check on the oil pressure and cad cell as far as the nozzle, I replaced it 2 years ago. Appreciate the feed back. I will respond with results tomorrow!
Old 01-01-2015, 12:19 AM   #5
Rewards Points: 6
Thanks beenthere!! I'll check the cad cell once I read up on it, I'm new to this but my location is in Central Michigan.
Old 01-01-2015, 08:04 AM   #6
An old Tradesmen
Nozzle should be changed every year.
Tags
furnace , heating and cooling , oil burner
Quote for new furnace. Reasonable? dengle HVAC 16 03-04-2012 07:01 AM
Help with furnace blower problem Spydey HVAC 6 12-15-2010 08:18 PM
Payne PG9YAB high efficiency 95% furnace water draining problem jchen64 HVAC 9 12-06-2010 06:42 PM
Strange Problem with My Furnace chenjijc HVAC 14 11-04-2009 09:05 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
