Frustrated: Switching From Robertshaw 8625 Thermostat To Hunter 4155c - HVAC - DIY Chatroom Home Improvement Forum
Old 04-10-2011, 09:42 PM   #1
Frustrated: switching from robertshaw 8625 thermostat to hunter 4155c
I am changing programmable thermostats from a robertshaw 8625 to a hunter 41255c. the following wires were hooked up to the robertshaw:
red wire- R- 24 VAC return
blue wire- C- 24 vac transformer common side
yellow wire- Y1- Compressor relay stage 1
orange wire- O- reversing valave (cool active)
white wireand brown wire-W2/E- 2nd stage heating control.
The humter 4155c shows the following in the manual:
RH= 24 volt- previous label rh/r/vr/4
RC= 34 volt cool- previous wire labelRC/VC
Y/O= a/c compressor- previous wire Y/C/M/O
W/B= heating
G= Fan previous wire G/F
Y1= heat pump compressor- previous wire Y1
can somebody please help me figure out which wires goes with which new connection. I am not that electrical savvy, and have been trying to figure it out for two hours now.
jrob514 is offline   Reply With Quote
Old 04-10-2011, 11:04 PM   #2
I'm Your Huckleberry
Rewards Points: 2,270
I do believe you're going to need a stat with a common terminal.
red wire to the rh or rc terminal with a jumper wire to the other.
orange and yellow to the y/o on the new stat, cool and reversing valve. cool active means that when the stat is calling for cool it energizes the reversing valve.
white wire to w/b
brown wire to Y1.
there needs to be a wire, most likely a green one, to the fan/g terminal. your old stat should have one.
the last two, the brown and the white, may need to be switched as it's first and secondary heat but again, nothing may work without that common wire, it is needed to close all calling circuits.
Doc Holliday is offline   Reply With Quote
Old 04-11-2011, 04:41 AM   #3
An old Tradesmen
Rewards Points: 6,850
Orange and yellow wire can't both be on the Y terminal. It would not be able to go into heat mode wired that way.
Check the install manual. Should tell you if you can program the Y/O to just be an O function terminal.
The Following User Says Thank You to beenthere For This Useful Post:
Doc Holliday (04-11-2011)
Old 04-11-2011, 05:14 PM   #4
AKA HVACTECHFW
Rewards Points: 1,208
that thermostat will not work with a heat pump with aux heat.
from the owners manual
This thermostat is designed to work on the following
heating and cooling systems:
Gas – Standing Pilot
Gas – Electronic Ignition
Gas – Fired Boilers
Gas – Milivolt Systems
Oil – Fired Boilers
Oil – Fired Furnace
Electric Furnace
Electric Air Conditioning
Single Stage Heat Pump - No auxilary
This thermostat is not designed for multi-stage heat
pump systems or 110/220 V baseboard heating
systems.
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 04-11-2011, 11:24 PM   #5
Thanks.
Hunter Thermostat Model 44860 Heat Pump Emergency Heat Does Not Work On Auto stvnhdmpa HVAC 8 12-08-2010 05:44 PM
Wiring on Hunter Analog Thermostat woomama HVAC 16 03-22-2010 01:52 PM
Upgraded to new Hunter model 44860 thermostat and now no emergency heat hlmaint HVAC 0 01-08-2010 01:17 PM
Hunter 44668 Thermostat - Heat won't turn off ToneyRes HVAC 9 10-18-2009 08:50 PM
Hunter Thermostat Problem kohlernm HVAC 1 11-22-2007 09:58 PM
