Frozen Fingers - HVAC - DIY Chatroom Home Improvement Forum
Old 04-17-2015, 11:07 PM   #1
Rewards Points: 258
Frozen fingers
Decided to make sure the AC was working before it actually gets hot here. It didnt. I went to check pressure and hooked up the guages. Pressure was good but when I unscrewed the hose, the schraeder valve stuck for a minute. I hurried up putting the cap on to stop it and nearly frostbit my fingers doing it . Question is, what kind of glove could a guy wear for protection and still be able to work ?
Next step was to check the thermostat and I found a bad connection. Tightened that and all is good.
JackDidley is offline   Reply With Quote
Old 04-18-2015, 05:28 AM   #2
An old Tradesmen
Rewards Points: 7,440
Frozen fingers
Leather for hose connection and disconnect.
Now it will be real fun taking that cap back off.
Old 04-18-2015, 07:38 AM   #3
Rewards Points: 258
Frozen fingers
Leather it will be. Its at the A coil. I can close the valves at the compressor and let the pressure bleed down. Then replace the valve. That valve was leaking when the A coil was new and I replaced it then. Is there a certain brand or supplier I need to look for to get something better ?
Old 04-18-2015, 08:31 AM   #4
An old Tradesmen
Frozen fingers
No, I don't even look at the brand when I buy them.
Old 04-18-2015, 09:02 AM   #5
Hvac Pro
Rewards Points: 484
Frozen fingers
If it has a brass flare nut cap then tighten it down secure and forget it. You do not need to check pressures at the coil. Outside is the place. If it is not leaking then leave it alone is what I would do. Need refrig leak soap/gas leak detector not dishsoap to make sure it does not have a tiny leak now. NuCalgon is what I use. May have lost a ounce or more and need to have some added.
http://www.nucalgon.com/products/gas-leak-detectors
Old 04-18-2015, 12:33 PM   #6
Rewards Points: 842
Frozen fingers
How much refrigerant got out? Was it enough to affect operation?
roughneck is online now   Reply With Quote
Old 04-18-2015, 06:06 PM   #7
Rewards Points: 258
Frozen fingers
I dont think I lost much. I just got home and kicked it on. OUtside, it 80*F. Inside, 77*. Out the vents 55*. Only been running 10 minutes.
Old 04-18-2015, 06:47 PM   #8
An old Tradesmen
Frozen fingers
Check it in another 10 minutes. Should be more then 12 degrees colder then the indoor temp.
Old 04-18-2015, 06:49 PM   #9
Hvac Pro
Rewards Points: 484
Frozen fingers
77 indoor - 55 supply = 22 Delta T. It is fine. 18-20 deg is normal, 22 great.
The Following User Says Thank You to yuri For This Useful Post:
ben's plumbing (04-19-2015)
Old 04-18-2015, 07:26 PM   #10
Rewards Points: 258
Frozen fingers
Got to 75* that it is set for and shut off fairly quick. Going to be cool here, the next few days so it will not run much. I will check pressure at the port on the outside unit next time if its not getting the job done.
Old 04-19-2015, 05:44 AM   #11
An old Tradesmen
Frozen fingers
LOL, it was a long day yesterday. Boy was my math off.
The Following User Says Thank You to beenthere For This Useful Post:
Outside water pipe frozen daveyboy43 Plumbing 7 02-23-2015 12:04 PM
Insulating to prevent frozen pipes Sackeret General DIY Discussions 11 01-11-2014 11:41 AM
Is frozen joint compound acceptable once it has thawed? Deck Drywall & Plaster 11 01-02-2013 11:12 PM
HOW TO make better frozen pizza Nestor_Kelebay Off Topic 13 06-08-2010 10:11 AM
"presumed" frozen water pipes mikeinKy Plumbing 23 01-26-2008 11:32 AM
