Frozen AC Furnace - HVAC - DIY Chatroom Home Improvement Forum
Old 07-01-2011, 12:28 AM   #1
Frozen AC Furnace
I am a complete novice with this stuff so forgive me if I use incorrect terms/explanations.
I have refrigerated air and live in an apartment style condo. My furnace is freezing when running the AC for only a few hours or less. It is building up frost around the thick connection. The ac guy that came last time mentioned that it can freeze and cause the air flow to block. I do not know where to start with preventing this from freezing, please help!
Here is where it is visibly freezing(not frozen in picture)
Thank you for any help!
hastethechariot is offline   Reply With Quote
Old 07-01-2011, 06:12 AM   #2
AKA HVACTECHFW
Rewards Points: 1,208
low refrigerant charge and poor air flow will cause the evap to freeze.... these are the most common reason. Check your filter and if clean call a pro to have refrigerant level checked.
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
The Following User Says Thank You to hvactech126 For This Useful Post:
hastethechariot (07-01-2011)
Old 07-01-2011, 02:16 PM   #3
Thank you!
Thanks for the fast response. I checked the filer and it was dirty even though it was only 1 month old. I have replaced it and will test now. Thanks so much for your help. I will post how it works.
Old 07-01-2011, 03:01 PM   #4
Rewards Points: 338
You most likely have a refrigerant leak, a one month old filter is not going to cause that much restriction in airflow. Leaks usually come from the evaporator coil which is located behind the green panel where the red arrow is on the picture where the lines enter the air handler. If you can remove the panel and look at the coil, that will give you an idea. The coil could be dirty and/or the coil could be old and rusting badly to the point where pinhole leaks are developing and causing a slow refrigerant leak.
NitroNate is offline   Reply With Quote
Lennox Furnace G27M Series Unreliable operation: pressure switch or else? sheppard1977 HVAC 7 01-14-2013 05:42 PM
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 03:51 PM
Furnace Model # Feh-015-04 clicking but not turning on? haimei HVAC 1 12-14-2010 05:01 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 01:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
