Frost Clogging Furnace Air Intake - HVAC - DIY Chatroom Home Improvement Forum
Old 01-21-2009, 02:04 PM   #1
frost clogging furnace air intake
I have a high efficency gas furnace installed to manufacturers recomendations with both exhaust and intake air exiting the house thru a side wall. Occasionally in the winter (it seeems more often this winter)the air intake will frost up and clog the intake (3") pipe and shuts down the furnace. Is there any good way to prevent this happening? Thanks
geep is offline   Reply With Quote
Old 01-21-2009, 02:24 PM   #2
JohnH1's Avatar
Nope. I have many installed for our customers exactly like they should be and still have a lot of problems this year. More than normal. Now if it isnt installed correct you will have even more problems.
JohnH1 is offline   Reply With Quote
Old 01-21-2009, 05:44 PM   #3
The frost is usually caused by recirculating a little flue gase which contains moisture. About the only way to correct it is to increase the distance between the intake and exhaust. Maybe snorkel the exhaust.
SKIP4661 is offline   Reply With Quote
Old 01-21-2009, 05:55 PM   #4
Hvac Pro
yuri's Avatar
Rewards Points: 1,756
Post some pics of it and the surrounding area. If you have bushes/fence/corner wall nearby that can cause the wind to swirl and under the right conditions cause recirculation of the exhaust to the intake. Removing any snow or bushes nearby can sometimes help.
Old 01-22-2009, 10:03 AM   #5
Thanks for the advice, the real problem is that we will be away for a month and I am afraid it will shut down the furnace and the neighbor watching the house will not know what to do. I wonder if I put a solid divider between the exhaust and intake if that will keep enough of the moisture laden exhaust away from the intake and avoid the frost, or another alternative install a "Y" in the intake with a removable cap and simply open it while we are away. The basement is not air tight or heated.
Old 01-22-2009, 04:32 PM   #6
Hvac Pro
yuri's Avatar
MAKE sure the neighbor knows what to do/how to unplug the pipe and reset the power to the furnace to start the unit. Until you have a proven method to prevent that from happening I would not tempt fate. My Dad drains his water pipes/shuts off gas to water heater/leaves his taps open when he goes away to Texas for the winter. Also has a alarm co monitor the basement temp and gets the neighbor to check the house.
Help My Admiral Refrigerator is leaking water Cuwillis Appliances 10 03-25-2014 08:21 AM
Lennox Furnace G27M Series Unreliable operation: pressure switch or else? sheppard1977 HVAC 7 01-14-2013 05:42 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 01:55 PM
Furnace installed. Intake from outside. DO i need it? Northland101 HVAC 5 11-28-2008 02:03 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
