Frost Around Pipe From Heat Pump To Furnace - HVAC - DIY Chatroom Home Improvement Forum
Old 04-09-2010, 10:06 PM   #1
Frost around pipe from Heat Pump to furnace
Last week I changed the location of my thermostat due to some inside renovations. I made sure everything was wired correctly, but ever since I removed it only cold air blows from the registers. This went on for a week, and while it would periodically blow heat, for the most part it only blew cold.
Tonight I just happened to walk past the heat pump and noticed ice around the pipe from the heat pump to the furnace in the attic. I looked inside the heat pump and the piping was completely covered in ice and frost. I went in the attic and there was frost around all the piping (I could see it where the insulation was tied to the pipe).
I am not sure what is wrong with the system, I know it was something that I had done because I didn't notice anything until I moved the thermostat. Also this entire winter the heat pump would run very loudly, but didn't notice anything wrong with the pipes or anything else. Any help would be much appreciated and have a good day!
Thank you,
William
Heat Pump: Amana TempAssure RFH24
stumpw is offline   Reply With Quote
Old 04-10-2010, 05:48 AM   #2
An old Tradesmen
Rewards Points: 6,846
Might be low on charge, since you said it was loud this winter.
Was last week, the first time you used it cor cooling since you changed the thermostat.
Old 04-10-2010, 05:53 AM   #3
Check in the thermostat for wires shorted. Also see if there's a little switch labled O/B, it should be in the O position.
Old 04-10-2010, 06:55 AM   #4
beenthere: After I check the O/B switch I'll look into getting it recharged, and I was actually using the heat pump for heating last week. I think that's why I was suprised to see everything frosted.
Marty S: I'll check the O/B switch, I remember seeing that while fixing the wires, I'll also check to see if there's anything exposed in the wiring that would cause a short. Can you tell me what the O/B switch is for? What to they stand for?
Thank you guys! If anyone has any other suggestions please let me know!
Old 04-10-2010, 12:39 PM   #5
That's the 24 volts to your reversing valve. Most heat pumps energize it in cooling, the O position. Rheem/ Ruud is the only one I know of the uses the B position. A short in the O wire or the switch in the wrong position will have it cooling when calling for heat and cause the freeze up.
Old 04-10-2010, 09:45 PM   #6
Thank you guys! It looked like the switch was accidentally set to B when I moved it. Now, if I could only make that sound go away. I will probably see if a friend knows a friend in HVAC that can come out and help me. If I have any other problems I will definitely be back here! Thanks again.
How to stop auxillary heat from coming on defrost cycle and limit auxillary heat use? twilightcall HVAC 34 12-28-2010 06:53 PM
New Heat Pump Problems Cooling Zombify HVAC 2 04-06-2010 03:42 PM
What temp does my Heat Pump stop producing good heat or what is the threshold? twilightcall HVAC 15 02-12-2010 09:46 PM
heat pump question David from MD HVAC 3 02-01-2010 08:42 PM
heat pump cut off set point oldswab HVAC 4 12-02-2009 02:09 PM
