Frigidaire FG6 No Gas - HVAC - DIY Chatroom Home Improvement Forum
Old 10-07-2012, 06:36 PM   #1
Frigidaire FG6 no gas
I don't normally work with funaces though I do understand, for the most part, how they work. I'm a bit perplexed about a problem I'm having with the FG6 as I'm not seeing what I'd expect.
The firing sequence makes it all the way to the hot surface ignitor glowing but there's no gas. After a while the ignitor goes out but the controller never trips out - it just keeps cycling between venting and ignition.
My first thought was bad gas valve as it shouldn't be powering the ignitor unless all the safeties are all happy. I disconnected the valve power and hooked up my meter. As expected the furnace tripped saying the gas valve was bad but what I didn't expect to see was a constant 14V up until the trip. I thought to see 0V until after the ignitor was glowing brightly then see 24V.
I checked the thermostat terminals and those have 24V so I assume the transformer is good.
I expect tomorrow I'll have to start checking the control voltage at each safety (had to go out so couldn't do it today) to see if one of them is to blame or if the control board is only supplying 14V somehow.
Any thoughts what to check other than the above?
Thanks!
pmeloy is offline   Reply With Quote
Frigidaire Loud Fan Noise C_J_GO Appliances 7 02-12-2017 02:38 AM
Frigidaire electric dryer neight Electrical 2 10-31-2010 10:18 AM
Messed up Ice Dispenser on Frigidaire mwha1389 Appliances 1 07-21-2010 07:58 AM
Frigidaire FRS26ZSH won't dispense water BarbaraF Appliances 1 12-14-2009 06:30 AM
Frigidaire Refrigerator Noisy cjyphoto Appliances 4 12-28-2008 09:33 PM
