Fresh Outside Air For HVAC - HVAC - DIY Chatroom Home Improvement Forum
Old 02-05-2009, 12:26 PM   #1
Rewards Points: 1,088
Fresh Outside Air for HVAC
I had a preventive service check today, and the tech examined my zone 1 (of 2) system that heats my basement and first floor. Zone 2 heats the 2nd floor.
We had a discussion where I pointed out the lack of a return in the basement, but two on the first floor. I thought this was ok to prevent any radon gas or basement air to be circulated upstairs. He checked this return out and noted an additional duct connected to the return trunk.
Upon further investigation, we discovered that this extra duct drew cold air from the outside air. He said my house was not super tight, so he closed this outside draw and said it was not needed.
Is it needed?
handy man88 is offline   Reply With Quote
Old 02-05-2009, 03:20 PM   #2
An old Tradesmen
Rewards Points: 7,372
Depends.
Is your furnace a direct vent, r does it get its combustion air from the basement.
It may be needed to also provide air for combustion.
Old 02-05-2009, 07:10 PM   #3
Originally Posted by beenthere View Post
Depends.
It gets its combustion air from the basement. The air vent for the outside air is connected to the return trunk.
Old 02-06-2009, 02:54 PM   #4
30 year tech
hvac122's Avatar
It all depends on where you want to get your fresh air from. The air in that pipe is clean and getting conditioned before it gets to the living area. Other air entering your house through the attic or can lights for instance is dirty air bringing things like insulation and dust into your house. I would rather have the clean air.
Around here a fresh air pipe into the return air is code.
hvac122 is offline   Reply With Quote
Old 02-06-2009, 03:06 PM   #5
An old Tradesmen
I'd open it.
Its probably helping to supply some of your combustion air.
Old 02-07-2009, 05:07 AM   #6
G71
Pro
Is that in a 6" pipe, if it's connected to the r.a., why not use an automatic fresh air set up, we install them here,(code to have fresh outside air), Aprilaire makes a nice one, can find info on their website.
G71 is offline   Reply With Quote
Fresh Air Intake for new boiler? nperkins HVAC 15 09-15-2014 05:02 PM
Home Fresh Vent system VAN HVAC 1 11-14-2008 08:23 PM
Fresh Air Intake Location? AustinDIY HVAC 3 05-01-2008 09:37 AM
Fresh air home ventilation Jeekinz HVAC 7 04-18-2007 03:08 PM
