Old 09-04-2012, 11:19 PM   #1
fresh air vent question
I have a manufactured home with a full unfinished basement. My water heater is located in the upstairs closet and is propane with a intake vent dropped into the basement. We installed a high efficiency furnace in the basement that has a pvc exhaust and intake pipe installed on this. I also added a wood insert fireplace that is vented into the basement also. My question is that I have a 6 inch flex coming from the outside and drops into a 5 gallon bucket above the floor about 12 inches for makeup/combustion air. I also cut a 6 inch grill register in my return air in the basement also after installing the fresh air vent. I currently run a dehumidifier in the basement at all times around 45%. Is it okay to have this setup the way I do is all I am wondering and hope to hear some input if this is wrong. Thanks
gregdk is offline   Reply With Quote
Old 09-05-2012, 10:08 AM   #2
Bchill
honestly, it sounds bad... every appliance should have its own fresh air intake if ones required.
Affordable Comfort, assisting with
and surrounding area, as well as offering 24 hour
Acomfort is offline   Reply With Quote
Old 09-05-2012, 10:22 AM   #3
So you feel that a 6 inch flex from the outside isn't enough to supply a water heater,fireplace and overall pressurizing of the home? The grill I cut in the furnace return is just for supplying some fresh air to the upstairs. What should I change?
Ridge Vent Installed - what to do about soffits nickc3 Roofing/Siding 3 07-02-2012 05:26 AM
Gas furnace exhaust vent question nowell HVAC 7 01-30-2012 09:31 AM
Roof Vent Question jrref Roofing/Siding 3 04-10-2011 06:20 PM
"Can of Worms" stack vent question ChrisDIY Plumbing 12 12-03-2010 12:42 PM
Return air vent question sidewayzisbest HVAC 5 05-10-2009 04:39 PM
