Fresh Air Return On Furnace Necessary - HVAC - DIY Chatroom Home Improvement Forum
Old 12-16-2012, 10:56 AM   #1
Rewards Points: 113
Fresh air return on furnace necessary
I live in Michigan. Home was built in 1997 and is a modular design. We have a 90+ furnace a/c unit. Is it necessary to have a fresh air return that goes to my main return air trunk. If you need fresh air return wouldn't that interfere with the heating and cooling by reducing it's efficiency? Is there a way to increase efficiency in way of special damper? Our water heater is a Rinnai tankless. Thanks for any suggestions.
EFTHIM is offline   Reply With Quote
Old 12-16-2012, 11:03 AM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 1,454
you need a fresh air intake if you have stale air, cooking smells, odors, smoking or too much humidity in the Winter. If not then don't bother. Google Hoyme damper if you want to know more about a damper to shut it off in the off cycles.
Old 12-16-2012, 11:15 AM   #3
Experienced HVAC Tech
HVAC1000's Avatar
the fresh air is there because the builder felt they build your house so tightly that it doesn't leak. this is good and bad because your house is energy efficient however if u take a shower, cook, or even just breath in your house the humidity will stay in your house and over time grow mold and mildew and cause paint to peel. the fresh air helps prevent that by reducing the relative humidity. Honeywell makes a very nice ventilation box that mixes the fresh air with already heated air before piping it into the return trunk. Using this makes it less of a shock to your furnace and better ensures the air will be heated properly and efficiently.
http://yourhome.honeywell.com/home/P...ummaryList.htm
HVAC1000 is offline   Reply With Quote
Old 12-16-2012, 11:22 AM   #4
Hvac Pro
yuri's Avatar
Modular home? is that the same as a mobile home? The building code in Canada says that all new homes need a fresh air pipe into the RA duct as they are all very tight nowadays and the code just changed to you must have a basic HRV.
Lennox Furnace G27M Series Unreliable operation: pressure switch or else? sheppard1977 HVAC 7 01-14-2013 06:42 PM
Heil Furnace problem - is is the undersized vent? mpmusicny HVAC 8 11-20-2012 01:47 PM
Furnace air filtration advice stephen_smith HVAC 7 12-24-2010 03:24 AM
Cold air return grill at furnace intake Zeke2112 HVAC 6 11-20-2009 07:41 AM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 02:45 AM
