Old 09-27-2010, 08:23 PM   #1
fresh air intake requirements
hi all,
i'm getting a hi-efficiency Heil furnace installed to replace an old unit. it's in the garage. do i need to take fresh air from outside, or can i use the garage air? we're in the temperate NW.
thanks,
sriegel is offline   Reply With Quote
Old 09-27-2010, 08:40 PM   #2
HVAC / Plumbing
This depends on the size of the garage & what is required in your area. Your installer should know the requirments for your area & your situation. In my area. no outside air is required if the garage area is large enough. If it's a 90 % furnace. there should be a pipe for combustion air & 1 for exhaust
kenmac is offline   Reply With Quote
Old 09-27-2010, 08:49 PM   #3
thanks,
well, my old house used both intake and exhaust, but it was in my finished basement. i'm just wondering cuz he said we'd just unhook the old exhaust and that would supply enough combustion air. i've got about 550 square feet of attached garage. if it's strictly a volume requirement, i'm okay with it. i wasn't sure if it's a strict requirement for 90+ furnaces.
Old 09-27-2010, 09:08 PM   #4
HVAC / Plumbing
xxx combustion air per xxx BTU. I like to use both pipes 1 for exhaust the other for combustion air. Some use single ( a pipe within a pipe ) which does the same thing
Old 09-27-2010, 09:21 PM   #5
found it in the installation manual. we'll make sure we give 'er enough air.
thanks again for the help.
Old 09-27-2010, 09:25 PM   #6
Hvac Pro
There may be some local code requirements as to how high off the floor it has to sit. Hopefully the installer checks them out. Has to do with explosive fumes at floor level if there is a gasoline leak etc. A 2 pipe system would be safer.
Old 09-27-2010, 09:44 PM   #7
HVAC / Plumbing
Originally Posted by yuri View Post
Has to do with explosive fumes at floor level if there is a gasoline leak etc. .
We had that problem here until some manfactures starting enclosing the blower motor compartment
Old 09-27-2010, 10:03 PM   #8
Hvac Pro
If he does any wood working or dusty work in the garage I would recommend the 2 pipe system so it stays cleaner inside the furnace. And a sealed air filter box. A 2 pipe system is safer as no fumes or dust can enter the burner box.
fresh air intake for furnace Red Squirrel HVAC 6 05-21-2010 10:32 PM
Fresh air intake damper - Open or Closed? dtran HVAC 7 01-06-2009 06:30 AM
Fresh Air Intake for new boiler? nperkins HVAC 14 12-30-2008 03:59 PM
Fresh Air Intake Location? AustinDIY HVAC 3 05-01-2008 10:37 AM
Fresh air intake vent Topher23 HVAC 7 02-26-2008 09:12 PM
