Freon On The Water. - HVAC - DIY Chatroom Home Improvement Forum
Old 10-12-2010, 06:52 PM   #1
JJboy's Avatar
Freon on the water.
Does water coming from the drain line ( outside the house ) can have freon indicating that the evaporator coil is leaking?
jjboy2k
JJboy is offline   Reply With Quote
Old 10-12-2010, 07:05 PM   #2
Rewards Points: 6,652
Highly unlikely, due to Freon is a pressurized liquid that turns into a gas when it escapes into the atmosphere.
Old 10-12-2010, 07:25 PM   #3
JJboy's Avatar
The air conditioning technician used an electronic freon leak test on water. The test made a strong sound. He shows me the Gauge (blue) with 54 psig - 28F and explain to me that the suction line when is under 32F makes the line freeze.
Do you thing the evaporator coil is leaking and needed to be change?
Old 10-12-2010, 07:56 PM   #4
HVAC / Plumbing
I have used dye.. You can have him pressure test the A coil
kenmac is offline   Reply With Quote
Old 10-12-2010, 09:07 PM   #5
Drain lines can be used to check for a leak. The leak would have to be moderately heavy but r22 is heavier than air and will eventually settle to the lowest point available and can be detected at the drain exit point.
hvaclover is offline   Reply With Quote
Old 10-13-2010, 04:29 AM   #6
An old Tradesmen
Rewards Points: 7,792
jjboy2k
Yes it can.
Old 10-13-2010, 05:03 AM   #7
Originally Posted by beenthere View Post
Yes it can.
LOL i was service manager (for about a hour lol) of an engineer firm that did custom hvac systems for churches.
One system was four years old and had never held a charge over the summer.
Twenty ton condenser suction and liq line ran under ground to inside custom made furnace. Thee were two 900k furnaces..real nice set up a pleasure to work on.
I was leak checking with my h10a. I put the sensing wand down near the condensate drain. Five minutes later I find five ware holes in the evap.
I localized the leaks with the H10 and than got closer with a halide and finally soap bubbles pinpointed the problem.
The coil should have been covered by warranty cause it leaked from day one. Boss was too whipped by his wife to make righteous demand it be replaced.
The OEM's idea of a fix was to cut the bad passes at the 3/8 elbows and install lengths of 5/16 tubing.
When the boss told me he wanted that done I refused because the evap superheat would have been all wrong.
I refused to do it because the evap super heat would have been all wrong and would have killed the CU.
I quit/was canned take your pick. But I was not going to screw a church with a hack repair.
Old 10-13-2010, 06:18 AM   #8
Rewards Points: 1,216
The mechanic that did that knew his job and knew how to look for a leak the right way. things that a newcomer would not even think of.. don't let that mechanic get away trust him with the repair/replacement.
COLDIRON is offline   Reply With Quote
Old 10-13-2010, 08:10 PM   #9
Damn right he did
Old 10-14-2010, 09:52 AM   #10
Why don't you ask him put the leak detector right next to the A-coil and check to see if the coil is leaking ?
clocert is offline   Reply With Quote
Old 10-14-2010, 12:34 PM   #11
Whaaaaaaaat?
Old 10-14-2010, 02:32 PM   #12
Whaaaaaaaat?
Forget it Cold, probably some hateful person trolling..
Old 10-14-2010, 03:29 PM   #13
I agree forgetaboutit
Old 10-14-2010, 03:32 PM   #14
HVAC / Plumbing
That was you'll know if it's really leaking
Tags
freon on the water.
Sump pump pit water level --- problem de12 Plumbing 52 01-14-2016 07:46 AM
Gas Water Heater, water not hot enough - Thermostat or Sediment makunag Plumbing 15 08-27-2010 11:00 PM
Well Water snuggles2010 Plumbing 3 04-13-2010 01:36 PM
How Do I Properly Shock Chlorinate a Water Softner classicflytyer Plumbing 5 07-14-2009 12:15 AM
Low Hot Water Pressure btennant Plumbing 4 12-09-2008 09:31 PM
