Freezing Up Outside - HVAC - DIY Chatroom Home Improvement Forum
Old 07-14-2010, 10:25 PM   #1
Freezing up outside
Came home from work today and it was hot in the house. Recently had an issue after a low voltage situation with the power company and had to replace the capacitor(sp?) so I turned everything off and went outside to see if the compressor was running. It was but I noticed there was a big block of ice inside the compressor. Hosed off the ice. Came back in and realized the thermostat was set on 72. Checked the filter which was filthy! Changed that.
When the ac guy was here last month he checked the freon and it was fine. The compressor is about 3 years old. Any suggestions?
liz3372 is offline   Reply With Quote
Old 07-14-2010, 10:46 PM   #2
So what's the current problem? Did cleaning the filthy filter solve the issue? My suggestion is to properly maintain your system. (ie inside coil, outside coil and filters)
hennyh is offline   Reply With Quote
Old 07-14-2010, 10:59 PM   #3
I haven't tried turning it back on yet. I wasn't sure that was such a good idea. Trying to get some advice.
Old 07-14-2010, 11:00 PM   #4
Also, the outside unit is clean. Not sure where the inside coil is or how to maintain it.
Old 07-15-2010, 07:27 AM   #5
An old Tradesmen
Rewards Points: 6,460
If an "HVAC" tech was there last month. That air filter was probably already too dirty. Hard to check if the charge is ok or not, with a dirty air filter.
Turn it back on. And check if you have ice every 30 minutes for an hour or so. Good chance it was the dirty air filter that caused your problem.
Old 07-15-2010, 12:08 PM   #6
lloydb's Avatar
The dirty filter was probably enough to cause it to ice. I had to replace a blower for a lady who had the same problem.
lloydb is offline   Reply With Quote
Condenser freezing zep HVAC 2 01-30-2010 09:04 PM
freezing pipes / bad insulation plumber red Plumbing 10 01-30-2010 06:46 PM
freezing up in winter wetbar HVAC 11 12-31-2009 05:07 PM
Freezing pipes in master bathroom need a 993 Plumbing 8 11-29-2009 07:10 PM
How to keep attic pipes from freezing in winter with gable vents ErikKratz HVAC 7 07-11-2008 10:32 PM
