Freedom 90 Thermosat - HVAC - DIY Chatroom Home Improvement Forum
Old 08-23-2011, 02:05 AM   #1
Hello. I have an American Standard Freedom 90 furnace. Can anyone suggest a programmable type thermosat for the model # TXC050C4HPCO. The Honeywell RTH7400D does not work correctly. Thanks!
Matt
remlu68 is offline   Reply With Quote
Old 08-23-2011, 04:03 PM   #2
AKA HVACTECHFW
Rewards Points: 1,208
That is not a furnace model number.... Remove the doors on the furnace and look for a data plate/sticker. What do you mean it does not work properly? Do you have a heat pump dual fuel system?
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 08-24-2011, 02:00 AM   #3
It is model number AUC120C960B6 updraft. As far as not working properly, it locks out frequently after 3 attempts to start. I replaced the flame sensor but to no avail. It used to be on a round mercury thermostat. I am trying to trouble shoot it. I get 3 flashes on the error codes, says pressure switch, that checks good. Read somewhere where the programable thermostat might just be the culprit.Tired last yr of resetting it so many times.
Matt
Old 08-24-2011, 06:40 AM   #4
AKA HVACTECHFW
stat is NOT the culprit. if the switch is good then you have blocked intake or exhaust. or bad inducer.
IT IS WHAT IT IS
Old 09-06-2011, 12:03 PM   #5
I did check the intake and exhaust, neither are blocked.Is a inducer hard to replace, Inducer motor???
remlu is offline   Reply With Quote
Old 09-06-2011, 04:41 PM   #6
AKA HVACTECHFW
How did you check the flue pipes? An inducer motor assy is quite easy to change. Just ensure you put new silicone (high temp) on the back of the motor assy.
IT IS WHAT IT IS
Old 09-07-2011, 01:34 AM   #7
The intake has a small screen on a PCV "U'. Nothing found in there, wasp etc. I took off the vented cap that is for the exhaust and looked inside. Nothing there either. Could the inducer motor be weak or something like that??
Old 09-07-2011, 06:33 AM   #8
AKA HVACTECHFW
remove the screen on the intake and recheck. the motor could be weak but often it is not that. Remove the burner box door and then retry. Previously you said the press. switch checked good; how did you check this? Because you can't properly check it without a manometer. if it works with the door removed then remove the pvc intake at the furnace and then retry. Often the blockage occurs all the way at the furnace and you can't see it by looking in the flues from outside the home. Often the pvc must be cut and opened up to view inside. Also while it cut open you can run a fish tape through it or hook up a shop vac on the outward port and hook that to the pvc to blow anything inside out ; however, this does not always work
IT IS WHAT IT IS
Old 09-30-2011, 02:10 AM   #9
Freedom 90 Burners
Does anyone know where I can get 6 Freedom 90 updraft burners for a model number AVC120C960B6?? Thanks
Old 09-30-2011, 04:13 PM   #10
AKA HVACTECHFW
google american standard burner.... or trane burner....
IT IS WHAT IT IS
American standard freedom 90 error code CAMERON12 HVAC 3 01-30-2011 09:44 PM
american standard freedom 80 works or shuts off in 10min racebum HVAC 0 01-24-2011 03:37 PM
American Standard Freedom 80 troubles johnmax HVAC 1 11-26-2008 12:43 AM
American Standard Freedom 90 4 flash code Gromit HVAC 1 11-25-2008 09:56 AM
american standard freedom 80 KEITH112 HVAC 5 11-12-2008 12:20 AM
