Freedom 80 Installation Manual AUD080C936H4 - HVAC - DIY Chatroom Home Improvement Forum
Old 12-31-2011, 06:24 PM   #1
Model: AUD080C936H4
S/N: M3212J41G
Hello All,
Where might I find installation instructions for this furnace?
The manual that came with the unit has circuit diagrams and other cool stuff, but no information on venting, direct venting, sidewall venting, or booster fan application.
My inspector, per IFGC 2009, needs manufacturer's installation instructions to guide him on approving sidewall venting. Any thoughts?
Thanks,
James
lavery is offline   Reply With Quote
Old 12-31-2011, 06:34 PM   #2
I'm Your Huckleberry
Rewards Points: 2,270
http://3110505851073047441-a-1802744...attredirects=0
Thanks.
Doc Holliday is offline   Reply With Quote
Old 12-31-2011, 06:45 PM   #3
Btw, I found that on this site.
Help with an American Standard Freedom 80 Furnace
Thanks.
Old 12-31-2011, 08:48 PM   #4
Very Good Doc,
Thanks for the link.
The illustrations look very much like my furnace, and it contains the sidewall venting reference that I need.
However, the model numbers do not match mine. How do I convince my inspector that I have the correct instructions?
Thanks,
James
Old 12-31-2011, 09:01 PM   #5
Look very carefully this time. "A" may be the prefix to "U" and suffix may be "A through Z"
Yours is an AUDO which makes sense to me and is indeed the exact manual that should have been in the box with your furnace. I see an AUDO80 in there, a few of them and that is all you need. The rest of the numbers are irrevelant to the task at hand.
Thanks.
Old 12-31-2011, 10:22 PM   #6
Doc,
Thank you for your quick response and good information.
I could see the similarities to my AUDxx080xxxxx, but was not about to bring it to my inspector without some around-the-block experience to tell me that the manual matches the hardware.
I'll go with it.
James
Ruud Installation Manual? Ilias HVAC 17 08-18-2011 07:44 PM
Is this a bad Carrier Infinity installation? Justin1990 HVAC 5 07-22-2011 11:18 PM
Manual D Friction Rate Worksheet kilosos2 HVAC 38 01-11-2011 04:36 PM
Konecto Installation Tidbit jennydavis Flooring 9 01-06-2009 12:19 AM
Aluminum Soffit and Fascia Installation... MoparAutoworks Building & Construction 1 12-17-2006 07:46 AM
