Freedom 80 Furnace Electronic Ignitor Problems - HVAC - DIY Chatroom Home Improvement Forum
Old 01-21-2011, 10:08 AM   #1
freedom 80 furnace electronic ignitor problems
I put 2 Freedom 80 furnaces in my house in 2000. one is a 3 port, one is a four port. about 3 years ago, the electronic ignitors starting going out. i checked the ground, the propane pressure, cleaned the burners, and had voltage checked. I go through about 2/year/furnace. i can hear it fire off to the top port. sometimes it doesn't fire off the ports below and it cuts off and recycles. even if it uses the ignitor a lot in a winter season, shouldn't it last at least a season or two? i have found that if it only fires the top port, i can put my finger slightly in front of the gas orphice jet and it will fire the rest of the cylinders. Can you help with this?
koenig1501 is offline   Reply With Quote
Old 01-21-2011, 05:17 PM   #2
AKA HVACTECHFW
Rewards Points: 1,208
remove burners and clean the crossovers. Propane is very corrosive to burners and flame sensors. it would be a good idea to order stainless steel burners if your furnaces does not already have them. While you are in there clean the flame sensor as well.
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 01-21-2011, 05:22 PM   #3
An old Tradesmen
Rewards Points: 6,918
The furnaces need to be cleaned.
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 03:51 PM
Blower problem on American Standard Freedom 90 furnace ekimmo HVAC 8 08-27-2011 09:13 PM
Help with an American Standard Freedom 80 Furnace cschwer HVAC 21 02-08-2011 11:33 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 01:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
