Franken-furnace & Ac - HVAC - DIY Chatroom Home Improvement Forum
Old 05-30-2012, 11:43 AM   #1
Weekend Builder
Crackers's Avatar
Franken-furnace & ac
Just bought a house. Lennox furnace system.
Gas heats hot water in tank. Hotwater goes to furnace and heats air. Cold water returns to hot water tank.
Separate AC (1995) unit outside.
2 zones.
In winter you need to flip a switch to "heat", and in summer you need to flip same switch to "cool" for the heat / AC to work respectively.
BUT, this time of year (AC) the upstairs of my house is quite hot, mainfloor cold. Even when i turn the thermostat on main-floor way high (say, 80), and upstairs cold (say, 69), the main floor is cold, upstairs is hot.
Any ideas what to do?
Crackers is offline   Reply With Quote
Old 05-31-2012, 06:50 AM   #2
Rewards Points: 380
Pretty typical problem for a 2 story house. Likely has little ductwork to the second floor, as in the old days they only sized and placed ducting for heating (no AC) so the heat would naturally rise to the second floor (so little ducting needed there).
You can run the fan in the "on" position continuously and that should help to keep the air a more even temperature between floors. If there are some registers you can turn down on the main floor (without loosing too much the airflow through the furnace) that may also push more air upstairs.
HVACDave is offline   Reply With Quote
Furnace Model # Feh-015-04 clicking but not turning on? haimei HVAC 1 12-14-2010 05:01 PM
Payne PG9YAB high efficiency 95% furnace water draining problem jchen64 HVAC 9 12-06-2010 06:42 PM
Carrier Infinity 69 Trouble Code 42 bodya1 HVAC 4 12-05-2010 06:43 PM
Problem with Trane gas furnace quovadis HVAC 17 12-22-2008 01:12 PM
Olsen BFL 120 Furnace DaleB HVAC 12 12-19-2008 10:42 PM
