Framing Around Mechanical - HVAC - DIY Chatroom Home Improvement Forum
Old 09-20-2011, 01:43 AM   #1
Framing around mechanical
I just purchased a house. It has the rough-in for a bathroom in the same area as the mechanical/hot water tank ect. I want to frame around it. I understand I will need access to replace hot water tank or to do any up grades. My question is. how close can I frame to the furnace/hot water tank? If I want to close it up do I need any venting in there? I was hoping I could frame most of it in and use large bi-fold doors as access.
Thanks.
I may post pictures, if helpful.
Maybe I should post this in plumbing too?
CFD123 is offline   Reply With Quote
Old 09-20-2011, 01:50 AM   #2
JJboy's Avatar
Smoke test
Oops
JJboy is offline   Reply With Quote
Old 09-20-2011, 06:12 AM   #3
An old Tradesmen
Rewards Points: 6,116
Check the install instruction for both the furnace and water heater, to see what clearances they say. And yes, you will need a combustion inlet.
Old 09-27-2011, 01:45 AM   #4
I see there is a vent that goes from the furnace to outside through the floor joists. I would be guessing that is what you call a combustion inlet?
Old 09-27-2011, 05:17 AM   #5
An old Tradesmen
Does it go from the furnace's burner compartment, or from the duct work.
pocket hole jointery and cabinet screws for framing newbymodeler Carpentry 29 03-07-2013 04:17 PM
Any opinions on panelized framing? TitaniumVT Building & Construction 5 12-29-2009 02:56 PM
Framing for drywall under Spiral staircase clemon03 Drywall & Plaster 6 07-17-2009 04:49 PM
Framing Gun - Nail Shank Diameter Questions... MoparAutoworks Building & Construction 5 07-03-2006 10:27 PM
Framing a 16 foot high wall for shop pranderson Building & Construction 10 01-01-2006 05:23 PM
