#1 |
Formula for finding CFM
BTHU output
CFM = _________________ = Temp rise x 1.08 Trane service guide says to get bthu output from furnace nameplate and multiply by the furnace efficiency (ex: 0.80) but I saw in another manual that doesn't need to multiply by the furnace efficiency. Wich one is correct?
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead. |
#2 |
JOATMON
Are we talking the BTU/CFM of gas?
If so... 1 CFM of gas is 1000 BTU (average) Hence, a 60,000 BTU furnace will need 60 CFM of gas to keep the furnace running at full output.
Common Sense is like Deodorant. Those that need it the most don't use it. My To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. ... To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. and To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Last edited by ddawg16; 01-11-2013 at 01:14 AM. |
#3 | |
Experienced HVAC Tech
Formula for finding CFMQuote:
#4 | |
An old Tradesmen
EG: 64,000BTU output, don't multiply. 80,000 BTU input, multiply, 80,000 X .8 equals 64,000 On a nat gas furnace, you should clock the meter to make sure it firing at its rated input. On LP, you should check the manifold pressure to make sure its firing at rated capacity. |
| The Following User Says Thank You to beenthere For This Useful Post: | JJboy (01-11-2013) |
#5 |
No, I'm talking about the air moviments.
#6 |
how much air the fan will move
| Display Modes | |
| Is there a formula? Please help | dtm888 | General Discussion | 8 | 02-13-2012 04:32 PM |
| Need a Formula | Livewire78 | Plumbing | 7 | 12-13-2009 09:19 PM |
| bundle formula | timothy918 | Roofing/Siding | 3 | 02-16-2009 06:36 PM |
| Formula for Main upgrade | hogger9 | Electrical | 6 | 09-28-2008 12:02 PM |
| stone veneer formula | tom1st | Landscaping & Lawn Care | 1 | 07-08-2006 05:48 PM |
