Old 01-29-2006, 07:28 PM   #1
Fored Air Furnace Won't Shut Off
My forced air furnace is shutting off at a temperature over 10 degrees what my thermostat is set at. The manufacturer is Suburban Manufacturing Company and the model is HF-50E,EC. I had Chuck from Chuck's Heat here and he said that I needed a new furnace because its over ten years old (the place was built in 1993). From what I have read, I think its the plenum temperature limit switch, but I haven't been able to figure out where that is. Perhaps its part of the circuit card?
Birdman is offline   Reply With Quote
Old 01-30-2006, 09:50 PM   #2
So I called Suburban today and they told me that Williams is/was the manufacturer. So I called Williams and had to leave a voice mail to request to purchase an owners manual. I haven't been called back yet. Does anybody have any idea what the problem with the furnace is?
Old 03-05-2006, 02:05 PM   #3
Do you have a newer digital thermostat or the older style with the mercury?
I would check the thermostat do see if it is telling the furnace to turn off at the proper temp.
redline is offline   Reply With Quote
Old 03-05-2006, 04:55 PM   #4
sub-contractor
reline is right.
I don't know who chucs heat is but, your problem is most likely that the thermostat is either broken or out of level.
The only reason to buy a new furnace when it is still functioning is if there is a hole in the heat exchanger. I still service furnaces that are 15 years old and working fine. but if there is any holes in the heat exchanger, i replace them.
Aceinstaller is offline   Reply With Quote
Old 03-16-2006, 06:50 AM   #5
weinstall.ca
Post
It could be the stat but
Check you furnace filter first. it may be blocked.
Also you may have replaced you filter wit one that is cause too much retriction.
Sometimes it may be the flame sensor losing a good signal
Let me know
Allan Thorne
Clarkson Comfort Zone Heating and Air Conditioning Mississauga Ontario
weinstall.ca
allan is offline   Reply With Quote
Old 03-18-2006, 02:42 PM   #6
sub-contractor
allan,
It's not short cycling. The problem is that it is running too long. you just gave the cures for a short cycling furnace.:p
Heil Furnace Burner Problem timothyr HVAC 78 01-18-2013 07:49 PM
Bryant Furnace main burner goes out after 5 seconds Da_Bears HVAC 8 01-03-2012 02:24 AM
Furnace not firing jax HVAC 5 02-22-2009 01:41 PM
Replacing My Furnace, few simple questions compression HVAC 10 02-03-2007 06:00 PM
Furnace stops working once a day - help Da_Bears HVAC 2 01-26-2006 02:19 PM
