Forced Hot Water Heat Wont Shut Off - HVAC - DIY Chatroom Home Improvement Forum
Old 11-01-2011, 06:06 PM   #1
Question
I have a house that was built in the 1950. It has since been updated with forced hot water heat. The issue is, since the power went out for about 36hrs, and now that its back on, the heat in the bedroom (zone 2 of 2) will not kick off. We have an older turn style thermostat. Its at least 75 degrees in the room at all times, and the thermostat is turned down to 45 degrees. The rest of the house (zone 1) is normal. Any suggestions?
Ice_Man is offline   Reply With Quote
Old 11-01-2011, 06:12 PM   #2
biggles's Avatar
remove the thermostat off the subbase...
Old 11-01-2011, 06:25 PM   #3
..... and just replace it?
Old 11-01-2011, 06:27 PM   #4
biggles's Avatar
no don't buy anything i just want to see if the zone shuts off.if it doesn't disconnect the wires
Old 11-01-2011, 06:32 PM   #5
Took the thermostat completely off zone 2 and the circulation pump wont stop. Any ideas?
Old 11-01-2011, 11:08 PM   #6
how
Rewards Points: 1,104
It could be a short anywhere across your thermostat lines but
the most common cause is usually a motor in the zone valve that has died in the "on" position. If you take the cover off your good zone valve and have someone turn on the thermostat that controls it, you'll see how the zone valve motor will crank a lever over to push in a switch. Now look inside the zone valve on the problem section to see if the lever is pushing in it's own switch.
If you kill the power to the boiler and the lever on the problem zone valve doesn't release from the switch, then replace that 24V motor.
Remember to cup your hand under the zone valve to catch the little screw when you are unscrewing the motor. That little screw was designed to fall, disapear and add an extra half hour to a plumber's vocabulary.
how is offline   Reply With Quote
Old 11-02-2011, 04:58 AM   #7
biggles's Avatar
the zone valve is stuck in the open position with the stat off the zone valve should close and the end switch opens up to shut the pump remove one wire going to the Normally Open contacts on the zone valve thee pump should shut of thru that relay package on the boiler
Hot water Heat repairs and our warranty Salvatorparadise General DIY Discussions 16 01-30-2011 11:35 PM
water borehole question joeuser General DIY Discussions 2 04-18-2010 10:33 PM
Need help with heat and hot water issue Spydey HVAC 50 03-07-2010 08:46 PM
Community water shut off zevon Plumbing 14 10-03-2008 07:16 AM
Is 1/2 Pex more restrictive than 1/2 copper? twilightcall Plumbing 19 06-24-2008 07:32 AM
