Forced Hot Air - HVAC - DIY Chatroom Home Improvement Forum
Old 12-25-2011, 08:19 AM   #1
Forced hot air
Have a heating vent in the kitchen, very close to the burner, its on an old outside wall, now there is a new room on other side, can I open up the othe side, for a vent, and use the existing line to get heat in the other room?
STEVE1103 is offline   Reply With Quote
Old 12-25-2011, 08:34 AM   #2
You can, but if it's possible to run a new duct that would be a better solution.
brandonmcginnis is offline   Reply With Quote
Old 12-25-2011, 09:24 AM   #3
Rewards Points: 582
sure can if the air comming out is blowing good an strong .....try not to use to many fittings....straight run is best..
Old 12-25-2011, 02:07 PM   #4
Rewards Points: 6,652
Also make sure that you put in a cold air return into that space.
The Following User Says Thank You to gregzoll For This Useful Post:
ben's plumbing (12-25-2011)
Electric Forced Air Furncace Fisher HVAC 0 02-08-2011 08:24 AM
home humidification without forced air heat? tastyratz HVAC 5 12-19-2010 06:19 AM
forced air heating system questions drewhart HVAC 6 01-25-2009 10:19 AM
Forced Air in 193 Year Old Home? jonathan03 HVAC 2 01-05-2009 08:47 PM
Goodman GMP100-3 Forced Air Furnace Will Not Ignite Meerkat HVAC 4 02-05-2008 09:44 PM
