Forced Air System Leaking - HVAC - DIY Chatroom Home Improvement Forum
Old 05-30-2011, 08:31 AM   #1
Forced air system leaking
Hi all,
I have a forced air conditioning / heating system at home. The handler is in my basement and condenser is on the side of the house. For some reason the air handler is shooting water out of every crack in the duct work where it connects to the handler. The condenser line is wet from the outside of the house all the way to the handler, and where it connects to the condenser outside there is a big block of ice on it. Any help would be greatly appreciated..
bklynjames is offline   Reply With Quote
Old 05-30-2011, 10:44 AM   #2
Rewards Points: 6,652
Because you have blockage on the drain for the air handler. Has nothing to do with the outside unit.
Old 05-30-2011, 11:20 AM   #3
Update.
Even thou the connection to the condenser unit outside has a block of ice on it?
Where would I find the drain on the air handler.?
Old 05-30-2011, 11:36 AM   #4
Again, because the inside unit is clogged and the drain is blocked. Has nothing to do with the outside condenser unit.
leaking pressure relief valve on heating water boiler benjamintr HVAC 13 01-29-2011 05:32 AM
Need advice RE: purging air from baseboard hot water heating system mikenri HVAC 2 01-19-2011 07:17 PM
Need advice on bleeding forced hot water heating system mikenri Plumbing 5 01-14-2011 07:29 PM
Is 1/2 Pex more restrictive than 1/2 copper? twilightcall Plumbing 19 06-24-2008 07:32 AM
Size A/C system properly 70stang HVAC 1 03-26-2006 07:22 PM
