Forced Air Return Duct Question - HVAC - DIY Chatroom Home Improvement Forum
Old 09-20-2012, 02:05 PM   #1
wood hobbyist
Forced air return duct question
Ok I'm building an attic playroom, total finished out space will be around 420 sq ft. (room size 30x14) my question is, currently the return air flexible ducting is two 12" and two 8" for the downstairs. The two that are 12" come from the same area almost. So I want to combine those two ducts into one to the air box, so I will have more space behind the knee wall on the side of the room. Is this possible without taking away/reducing the air source to the air hadler /forced air unit. So in redneck terms, I want to combine two 12" return ducts into one duct to the heating cooling air unit and it will still be for the downstairs only. Upstairs will have a seperate unit installed. Also is it possible to combine the two 8" returns? I attached a phot for everyone to see what I working with. Thanks for the imput in advance.
weberus3 is offline   Reply With Quote
Old 09-22-2012, 08:16 AM   #2
An old Tradesmen
Rewards Points: 6,870
1-16" can be used to replace the 2-12", and then 1=10" is just shy of 2-8". Are you going to use tee's or wyes to combine them. Wyes work better for air flow.
Old 09-25-2012, 12:49 PM   #3
wood hobbyist
Looking at doing it with wye's couldn't locate any 12" tees. Good idea going with the 14" and the 10". I didn't have that idea before I posted.
Old 09-25-2012, 02:56 PM   #4
Rewards Points: 610
that was a 16"..not 14" Big Difference.
techpappy is offline   Reply With Quote
cold air return reconfiguration question. hummer4x4guy HVAC 6 01-17-2012 02:56 PM
Help with return air duct gasbie HVAC 4 06-20-2011 06:54 PM
return air duct Brian F Brian F HVAC 1 04-28-2011 04:43 AM
Cold back room - question on duct insulation crazykidsdad HVAC 4 12-13-2010 12:59 PM
Exhaust fan / duct question vit HVAC 4 10-19-2009 03:51 PM
