forced air heating system questions
2K views 6 replies 2 participants last post by  drewhart
i am planning on installing a forced air natural gas furnace. the house is stucco, 4br, 1904 sq. ft. the house had radiant heat, but due to the multiple hard to fix leaks in the lines and thr broken boiler, i am opting to install forced air. it needs vents and everything. i just have some general questions, looking for a starting point for this. what are some good types of furnaces? how should i run the vents? where should i put them, high efficiency, high velocity vents? etc.
#4 ·
Do you have a place to run ducts up to the attic?
How much cutting do you plan to do Wall openings and such?
Do you have a basement is this where the furnace will go?
Are you prepared to build soffets?
You may want to contact a small local hvac shop, one that does new construction (not just a service shop). Ask them to come and give a estimate; before they come out explain that you would like to do some of the install yourself.
I have helped home owners this way in the past.
You may want to do all the floor, ceiling and wall cutting, have them install the furnace and the ducts. This way the job will be laid out right and you can save a few and get the job done cheaper.
#5 ·
yes i need to install all the ducts. there is a normal sized basement where the furnace will go. i dont care about knocking drywall out. i want to do all floor vents for the first floor. and i was thinking of running one vent to the attic that splits to feed the four bedrooms and the bathroom from the ceiling. im sure i can find a spot somewhere to run the a vent up to the attic. maybe somewhere where the water lines for the radiators are. the second floor has the subloor laid before the walls where put up, so i would have to cut out some drywall and cut a hole in this to allow something to run through to the attic. any other advice? how do i calculate the btu rating i will need? the boiler that was in there had an input rating of 131,250 btu. it was from the fifties maybe 60% efficient i would guess.
