Forced Air Heater Problems - HVAC - DIY Chatroom Home Improvement Forum
Old 10-24-2010, 12:32 PM   #1
Forced Air Heater problems
Just moved into my first house, one of the first things I replaced was the old dial thermostat that contained mercury. I replaced it with a digital Hunter.
The heater would normally click once to ignite, after about 45 seconds the blower would kick on. Lately I have started to notice that the ignition will continuously keep clicking, even after the blower turns on it continues to click. The heater displays that it's Normal Call For Heat, no other error code flashes.
I tried switching thermostats again to a Honeywell digital, it still continues to click. I also had an HVAC technician come in and of course my heater worked perfectly the entire time he was here, waste of a $100. So I am reluctant to call in another technician. Does anyone know what might be the problem? Is it possibly an easy fix?
Any help is appreciated, thanks.
retoid is offline   Reply With Quote
Old 10-24-2010, 12:37 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 150
Post make, model # and pics of unit with both front doors off and burner area.
Old 10-24-2010, 01:00 PM   #3
American Standard - Model# ADX060C936D
IMG_3112 by retoid, on Flickr
IMG_3114 by retoid, on Flickr
IMG_3116 by retoid, on Flickr
Here is a link to a video i took of it, you can hear the clicking.
http://www.flickr.com/photos/retoid/5108367474/
Old 10-24-2010, 01:27 PM   #4
Hvac Pro
yuri's Avatar
Rewards Points: 150
Try remove the tstat wires and jumper R to W and see if it stays on. Check your vent pipes for blockage. May be tripping on the pressure switch from blockage.
Old 10-24-2010, 01:48 PM   #5
which is the vent pipe?
the black pipe/tube on the bottom?
Old 10-24-2010, 01:51 PM   #6
Hvac Pro
yuri's Avatar
Rewards Points: 150
The plastic pipe coming out of the furnace. Otherwise you need to get an experienced tech to check the pressure switch etc while it is acting up. May have a bad relay on the board. Condensate trap may be plugging up etc. Gone for awhile now. Good Luck
Old 10-24-2010, 02:01 PM   #7
Ok thanks.
I removed the vent pipe, and vacuumed out most of the lint, though there was hardly any. Nothing noticeably blocking the passage.
Old 11-06-2010, 11:24 AM   #8
Removed the wires, as soon as i remove the tstat it initiates shut down.
I tried removing the jumper, didnt affect the continuous clicking.
The clicking sound seems to be coming from the smaller black box above the pressure switch.
Old 11-06-2010, 11:27 AM   #9
This is my problem, it's an automatic $100 visit from the HVAC technician, last time he came nothing was wrong. After he left it acted up again. Last night it was clicking a lot, this morning it is not.
I am eager to learn how to fix this myself. What would an experienced technician do to test the pressure switch while it's acting up?
I am having problems with my fuel oil pool heater fred Disk HVAC 4 09-06-2010 10:10 AM
Problems with water heater jwise Plumbing 11 02-26-2010 07:36 PM
REZNOR gas shop heater WHOOMP ! on ignition Wildcat355 HVAC 14 01-29-2010 05:57 PM
Which Gas Hot Water Heater walds11 Plumbing 66 01-16-2010 07:38 AM
Wiring to a water heater bvsmith_1974 Electrical 3 09-03-2008 03:32 AM
