Forced Air Furnace Blowers Making Noise - HVAC - DIY Chatroom Home Improvement Forum
Old 11-24-2008, 06:28 AM   #1
When is fishing season?
CowboyAndy's Avatar
Forced air furnace blowers making noise
Hey all, I have a problem with my newly installed Newmac cl86 wood/oil furnace.
Right after we installed it, we had a problem where the blowers sounded like they had marbles in it, turned out it was slightly off kilter, but now is dead on balls level.
Last night (this morning, actually) out of nowhere, it started making this "grinding gears" sound. The blowers would come on and sound normally, then the "marbles" sound would start building up gradually and after a few seconds sounds like grinding gears and would start the sequence of sounds over until they shut off. I went down to investigate, but being half asleep and not knowing much about hvac anyways, the only thing I did was tighten up the drive belt (which seemed loose). I checked, and it is still level.
the next few times it came on it was okay, sounded normal. After about a half hour, it started again, first with "marbles" then "grinding gears". Finally, it just had a slight "marbles" sound to it.
Any Ideas?
BTW, for what its worth the firnace was bought new in august and installed by my brother in law, who went to college for hvac, but is pretty new to the game.
I DON'T OWN MY HOUSE...
MY HOUSE OWNS ME!
CowboyAndy is offline   Reply With Quote
Old 11-24-2008, 09:35 AM   #2
Another DIY Zombie
Rewards Points: 264
Was this new furnace installed utilizing existing ductwork?
Could it be a static pressure problem? (Fan too powerful for existing D/W?)
Just a few thoughts...
javan is offline   Reply With Quote
Old 11-24-2008, 10:21 AM   #3
CowboyAndy's Avatar
yes, it was installed with existing ductwork.
Can you explain how that would cause a problem? What about the fact that it has been fine for almost 2 months, but now there is a problem?
MY HOUSE OWNS ME!
Old 11-24-2008, 11:43 AM   #4
Another DIY Zombie
Rewards Points: 264
Sorry, missed that part about the time-frame.
Now, I am curious. How long did it run before you fixed the level issue? Any chance that you damaged the bearings?
Regarding the ductwork question. Look at the installation manual and see where it talks about D/W connections. Depending on the rating of the furnace (CFM) and the size of the D/W connection, your fan may be trying to put too much air into the duct, but you would have this problem everytime the fan goes to high speed (assuming that you have a variable speed fan).
Old 11-24-2008, 12:07 PM   #5
CowboyAndy's Avatar
It was only about a day when it made noise the first time, about a week after we installed it. It has been well over a month since then.
Im not sure if its a variable speed fan, I couldnt find anything in the manual about it. As far as I can tell, it only runs one speed.
MY HOUSE OWNS ME!
Old 11-24-2008, 04:48 PM   #6
Mainah's Avatar
Make sure the pulley's are tight on both shafts-
Mainah is offline   Reply With Quote
Old 11-25-2008, 02:49 AM   #7
turn off the power and feel both sides of the blower wheel in relation to the housing(the part where its curved inwards) sounds like the wheel is dragging the housing and needs to be realigned on the shaft. if it is than loosen the set screw on the wheel and hold the pulley to lock the shaft, than work(turn) the wheel back and forth with your hand while gently pulling at the same time in the direction you need to move it. hopefully being new it will move fairly easy. make sure you almost back the set screw all the way out so it dosent drag the shaft and score it,being careful not to drop it(the set screw) or you may have to pull the blr/assm. to retrieve it also the fan blades can be sharp if you have any mechanics gloves id wear them
kennzz05 is offline   Reply With Quote
Old 11-25-2008, 07:07 AM   #8
CowboyAndy's Avatar
Well, sometimes the simplest explination is the one...
I took off the access panel, and staring me in the face was the set screw for the pulley, sitting right there on the ground. Damn thing worked itself all the way out!
Can I put a dab of thread lock on it?
MY HOUSE OWNS ME!
Old 11-25-2008, 05:04 PM   #9
Journeyman
Use the blue thread lock not the red, one day you will have to replace the pulley. With the red you will need a torch to remove the set screw.
pipefitter636 is offline   Reply With Quote
Old 11-26-2008, 01:56 AM   #10
Pilot light going out often...and furnace making a big "boom" sound Beth777 HVAC 20 01-22-2011 05:27 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 02:45 AM
Furnace blower motor noise rivershorereid HVAC 1 10-04-2008 03:31 PM
Furnace making noise munn HVAC 6 02-08-2007 11:25 PM
Toilet making Noise DSHMSH Plumbing 1 12-22-2005 05:33 PM
