Forced Air In 193 Year Old Home? - HVAC - DIY Chatroom Home Improvement Forum
Old 01-04-2009, 10:23 PM   #1
Forced Air in 193 Year Old Home?
I'm thinking of buying a 193 year old Victorian and I would like to add forced air so that it can be air conditioned. Its only a two story house and there is a basement under most of it. Right now the home has hot water heating and two window air conditioners in a 2800 sq ft home lol.....
Oddly enough, the first floor has vents but not tubing. The vent just goes right into the basement. I couldn't see anything to indicate that there was ever forced air since the existing hot water heater looks very very old and so does the piping.
So my question is how ridiculous would it be to try and add forced air into a home like this? Since this is an older home, the closets are literally 1' deep so it would be hard to get a pipe through there. Are there any tricks to doing something like this? The first floor would be easy as pie, but the second floor would be a pain in the rear end!
jonathan03 is offline   Reply With Quote
Old 01-05-2009, 07:31 AM   #2
biggles's Avatar
the closet is the first thing contrators go for when adding HVAC into an exsisting home,you might consider a system for the first floor with air handler in the basement.then a 2nd systems air handler for the attic/2nd floor closet to cover that area.basically you would have 2 zones totally seperate.hi velocity systems are actually PVC piping(no flex duct into the registers) is something to research also for limited applications like that 2nd floor.there should be install companies around you that specialize in what is considered a hi end application on an exsisting home of that age.
Old 01-05-2009, 07:47 PM   #3
Hvac Pro
yuri's Avatar
Rewards Points: 396
Make sure you get references from them/see pics of their work. Last thing you want is a hatchet job on some priceless old plaster mouldings etc.
Home Theater Set Up Help JAVAMAN Home Theater 3 03-12-2008 07:07 PM
Please Help - Weird electrical issue affecting home network sxpsxpsxp Electrical 23 02-03-2008 11:42 AM
Pay GC to construct home and finish it myself? L O N G . . . Badfish740 Off Topic 9 07-27-2007 08:44 AM
A facelift for your home Grumpy Remodeling 0 07-07-2004 07:43 PM
