Forced AC Unit Making Clanging Noise - HVAC - DIY Chatroom Home Improvement Forum
Old 07-26-2011, 06:10 AM   #1
Rewards Points: 334
Question
Forced AC unit making clanging noise
My forced AC unit started making what I can only describe as a more distinct propeller noise,with a little bit of metallic clanging noise yesterday(it used to be silky smooth). I popped the top to see if the fan blade was loose of if there was an obstruction and neither seemed to be the case. Any ideas?
The unit itself works fine. Recent work includes a new capacitor, Freon charge.
tripower is offline   Reply With Quote
Old 07-26-2011, 07:25 AM   #2
biggles's Avatar
free spin it in CW/CCW directions any grinding does the blade turn with a push and not brake hard
Old 07-27-2011, 06:24 AM   #3
Rewards Points: 334
Question
No, I didn't see any of that. In fact it will make that loud noise for a while and then revert back to quiet running. Any ideas?
Old 07-27-2011, 08:57 AM   #4
JJboy's Avatar
You need a new fan motor.
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 07-28-2011, 06:35 AM   #5
Rewards Points: 334
Question
How do I determine the proper replacement motor?
Old 07-31-2011, 12:32 PM   #6
Rewards Points: 334
Bump.
GE side-by-side making a whining noise jkrodger Appliances 2 09-11-2007 03:45 PM
Furnace making noise munn HVAC 6 02-08-2007 11:25 PM
Heat elements making noise helpless handyman HVAC 17 12-06-2006 03:49 PM
Making a doorway into a display unit Susie Carpentry 2 10-13-2006 08:37 PM
Toilet making Noise DSHMSH Plumbing 1 12-22-2005 05:33 PM
