Foil Tape Vs. Duct Tape For Ducting - HVAC - DIY Chatroom Home Improvement Forum
Old 03-03-2010, 12:29 PM   #1
Rewards Points: 1,062
Question
foil tape vs. duct tape for ducting
are the two pretty much interchangeable or are there specific uses for each kind ?
Old 03-03-2010, 01:35 PM   #2
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
duct tape is crap for taping ducts.
Foil tape or mastic (a gooey substance used to seal ducts) is what should be used. The foil tape has limitations. It does not stretch and as such, is limited to what it will seal. Mastic can be messy but does the best job, as far as I am concerned, if applied properly.
in fact, duct tape was not made to be used on ducts. It was invented during WWII by the military to seal ammo boxes. California specifically does not allow it's use on ducts. I understand some other states feel the same way.
Old 03-03-2010, 01:45 PM   #3
Exclamation
wow, not just an answer but also a history lesson thanks, dude !
Old 03-03-2010, 05:02 PM   #4
An old Tradesmen
Rewards Points: 6,500
As above. Duct tape is NOT for use on duct work.
Old 03-03-2010, 06:23 PM   #5
Rewards Points: 127
Actually, as I understand it, it was originally duck tape becaue the tape was made with a canvas 'duck' cloth base. Duct tape as a name evolved with usage.
ptarmigan61 is offline   Reply With Quote
Old 03-03-2010, 07:10 PM   #6
nap
You talking to me?
nap's Avatar
just call it 200 mph racer tape (that would be something like 322 kph for you in the Great White North)
Old 03-03-2010, 07:33 PM   #7
Hvac Pro
yuri's Avatar
Rewards Points: 1,414
Right on. we'll get you converted yet. Foil tape is high temperature resistant (to a point) and is sometimes used to seal air leaks on ducts better than duck tape as the glue in the duck dries out after a year and it falls off. The foil tape is on for many years and sometimes permanently. Plus wannabe tin bashers like myself can do a airtight installation much better. Mastic, especially the red duro dyne will get you really stoned in a hurry in an attic. Good for burning out unwanted brain cells.
Old 03-03-2010, 10:44 PM   #8
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
the inspectors around here are really pushing the sealing anything and everything around here,even if it doesnt leak.
We have to use the aluminum tape with ul181 stamped all over it,that mastic stuff is just nasty looking slopped on a new furnace/ductwork
plummen is offline   Reply With Quote
Old 03-03-2010, 10:53 PM   #9
nap
You talking to me?
nap's Avatar
but it does an excellent job if applied properly. It will seal areas that are difficult to get the tape to conform to.
and no cuts from the sharp edge of the tape
Old 03-03-2010, 10:56 PM   #10
An old Tradesmen
Use masking tape just like you wood if you were painting trim and didn't want to get any paint on the wall.
Makes it look much better.
Old 03-03-2010, 10:56 PM   #11
plummen's Avatar
thats the problem most of the guys around here slop it on like theyre painting a fence!
Old 03-05-2010, 05:44 AM   #12
Foil tape has 2 different ratings as well. The red lettered foil is code for crawl spaces...etc..where extreme variations in unheated spaces occur. If you use the regular foil tape an astute inspector will fail the job. Mastic best for permanent code complying seal....especially California's .5% loss law.
Affordable7 is offline   Reply With Quote
Old 03-05-2010, 01:55 PM   #13
Newbie Bill
Rewards Points: 520
Do you mean like in an application shown below?
you gotta love the red racing stripe on the RHS of the roof/trunk. Nice use of Red Duct Tape.
Bill
A DIY Noob that knows just enough to be dangerous.
drtbk4ever is offline   Reply With Quote
First time taping - Tape has air under it theedudenator Drywall & Plaster 16 04-22-2010 12:13 AM
Regular duct tape for bathroom exhaust? dtran HVAC 1 10-27-2009 04:26 AM
Duct tape for Range hood duct DIYGST HVAC 1 01-04-2009 06:46 AM
Tape for duct work? Willie5566 HVAC 4 01-16-2007 05:02 PM
Can I use duct tape? Dusty HVAC 2 09-27-2006 09:28 PM
