| DIY Forum | DIY Blogs | Photos | Woodworking | Extreme How To | Advertise | Contact Us |
Previous Thread
Next Thread
More On This Topic
Most people think about their water heater only when it fails. It's one of those things you couldn't live without, but as long as it does its job, you ignore it. And when it breaks down, you have no idea what to do. You can replace that old water heater... Read More »
Using Solar Panels for Water Heaters
by Expert Village
What you see here is a solar water heater. So totally different to photovoltaic or to solar electricity. This one is just using the sun to heat up water. And when you look close, I opened it up for you that you can see what's going on there. In here is... Read More »
How to Buy an Energy Efficient Hot Water Heater
by eHow.com
When you're trying to save money each month in energy costs, one of the first and best places to make a change is in the hot water system of your home. Homeowners can end up spending hundreds of dollars more per year than they should as a result of an... Read More »
by eHow.com
How to Use Tankless Hot Water Heaters
by eHow.com
Using your tankless water heater is as easy as turning on your faucet. Whether you have chosen a gas or electric water heater, using them is the same. Once the tankless water heater is properly installed, you simply turn on the hot water. Read More »
