#1 |
Just a DIY guy
foam block atop the compressor coil
I took the cover off of my old Carrier compressor (38EB060350) yesterday to clean it out with a hose. On top of the coil (and maybe the bottom too) there is a 1x1 inch piece of black foam, to block air from coming between the coil and the top of the frame (so the air comes through the coil and not around it). The foam is crumbly and I lost quite a bit of it.
What is that foam called, and where can I get it? Can I use something else to replace it? I don't suppose I can use Great Stuff spray foam? I know, I should have taken a photo but I did not. And I have not been able to find a diagram online that shows it. |
#2 |
An old Tradesmen
Don't use great stuff anywhere near your coil.
Use thick weather stripping like you get for a window A/C. |
| The Following User Says Thank You to beenthere For This Useful Post: | M3 Pete (07-21-2012) |
#3 |
Part of the Clover Leaf
strip of aluminum or galvanized sheet metal, from the local hardware, cut to size and held tight to top opening with heavy duty zip ties will do the trick too.
#4 | |
Just a DIY guy
foam block atop the compressor coilQuote:
http://www.homedepot.com/Frost-King/...ProductDisplay http://www.homedepot.com/Frost-King/...ProductDisplay |
| Display Modes | |
| Putting rigid foam on concrete walls...how to lay DriCore in this setup? | ChaoticBliss | Building & Construction | 14 | 09-12-2012 06:02 PM |
| New Guy Cincinnati | GB Greg | Introductions | 3 | 02-01-2011 08:15 PM |
| How To Install Rigid Foam Insulation on Concrete | earthad1 | Building & Construction | 9 | 10-26-2010 10:49 AM |
| fiberglass over rigid foam board in cantilever? | KatieAK | Building & Construction | 3 | 11-17-2009 08:48 PM |
| Fire blocking a wood stud wall built against cinder block. | BasementVirgin | Building & Construction | 1 | 10-06-2009 12:02 AM |
