Flushing A Steam Heat Furnance - HVAC - DIY Chatroom Home Improvement Forum
Old 11-06-2006, 12:21 PM   #1
Flushing a Steam Heat Furnance
Hi to all, I have a steam heat boiler on a house I just bought. We installed new pipes and I would like to do a boiler flush, to get rid of all the sediments that the boiler may have. I 've seen the boiler flush bottle in a plumbing store, and was wondering how or where do you pour this stuff into the boiler? Thanks to all!!!
helpless handyman is offline   Reply With Quote
Old 11-06-2006, 02:05 PM   #2
Thoroughbred Mopar Man
Rewards Points: 502
Hi helplesshandyman
The answer to your question could be a tough one, taking a wild guess here. You should have a condensate return tank with a pump, that is going to be the safest place to put it in. If yours pipes straight back top the boiler or is a gravity return system, you could have a boiler treatment canister on boiler, put cleaner in at this point. If you dont have either some boilers came with service plugs in the top of them, you could put it in there. Two things to remember when using a flushing chemical, make sure you mix it to the proper ratio with water, and make sure it is compatible with current boiler treatment being used. Remember high school chemistry, what happens when you mix acids and bases ( bases otherwise known as caustics).
Good luck
Rusty
#CARRIERMAN is offline   Reply With Quote
Old 11-06-2006, 04:34 PM   #3
World famous jerk.
Why do you feel the overwhelming need to do this? My experience is that you may be opening up a can of worms. Leave it be, is my advice.
mdshunk is offline   Reply With Quote
Getting a House..heatpump or no? DavidsCPU HVAC 10 02-07-2010 10:22 PM
Steam Heat still making banging noises helpless handyman HVAC 101 01-04-2008 03:43 PM
change steam radiant heat to outside wood water heat Monteu HVAC 5 02-13-2007 11:19 AM
Leaky Steam Heat Pipe NJE HVAC 6 01-30-2007 08:26 PM
Steam heat vs Hot water heat helpless handyman HVAC 5 10-03-2006 08:57 PM
