Flue Pipe Extended - HVAC - DIY Chatroom Home Improvement Forum
Old 12-14-2010, 03:25 PM   #1
flue pipe extended
hi i have been having a difficult time having to find someone that can extend my flue pipe up on the roof for my heating system last year snow storms because the flue is so short caused me to have no heat 2 different times because the snow was over the pipe i was told being the furnace has a safety feature if the flue is blocked the furnace just blows cool air so no carbon minoxide gets in the home it seems many of the contractors i called seem to avoid this kind of job but i had a contractor come here order a part spend nearly a half hour on the roof trying to put on the part he simply couldnt do the job told me he had the wrong part, could the problem be I own a remanufactured home with a miller gas furnance which many contractors might not be familiar with the miller furnance or any ideas where i can be looking for a contractor thank you
homeownerlookin is offline   Reply With Quote
Old 12-14-2010, 04:41 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,082
Ayuh,... I would think the people you have service the furnace should be capable, or know who is locally...
ask your fuel supplier maybe,..??
Bondo is online now   Reply With Quote
Old 12-14-2010, 04:49 PM   #3
hi thank you for the reply my fuel supplier refered me to someone that handles chimneys after contacting 2 of them locally they said they dont do that type of work, I am starting to think this is something thats just difficult to do or it takes a contractor thats very experience in doing.
Old 12-14-2010, 04:55 PM   #4
Reman homes are a unique animal and do require specialized parts. The furnace fllue and the furnace are made for only each other and you can't just add regular extension's.
Google Nordyne and go to manufactured housing or try this link
www.nordyne.com/web/MHLand.aspx
hvaclover is offline   Reply With Quote
Old 12-14-2010, 05:18 PM   #5
Hvac Pro
yuri's Avatar
Rewards Points: 1,868
Yep, that is a concentric pipe within a pipe type chimney and will ONLY work with the approved Miller chimney. Combustion air goes in the middle pipe and exhaust goes out the outer pipe or vice versa. CANNOT just add any extra pipe or it will be dangerous and void your house ins/ fire rating of furnace etc.
How to stop sump pump discharge pipe freezing??? relbeig Plumbing 8 11-12-2012 12:03 PM
AC Coil drain pipe questions fritzycat1 HVAC 14 11-12-2010 03:51 PM
running black gas pipe lukeg Plumbing 6 10-24-2009 11:16 PM
Newbie Solder Question SteveSmith98 Plumbing 9 01-15-2009 09:50 PM
PVC pipe broken on Gas Furnace/AC unit Keyo77 HVAC 8 10-16-2007 03:08 AM
