Flue Gases - HVAC - DIY Chatroom Home Improvement Forum
Old 12-18-2011, 10:03 AM   #1
flue gases
mechical room the water heater flue gases go into room with furnace fan on when fan shuts off flue gases go up flue how can problem be solved?
jwbaker1 is offline   Reply With Quote
Old 12-18-2011, 10:08 AM   #2
HVAC Tech/ Browns Fan
That room should have some kind of fresh air combustion
Tator1076 is offline   Reply With Quote
The Following User Says Thank You to Tator1076 For This Useful Post:
jwbaker1 (12-18-2011)
Old 12-18-2011, 10:17 AM   #3
biggles's Avatar
if the return isn't ducted to the furnace yes they will or the room return with louvered door is sucking air from the easiest area room down the flue of the HWH
The Following User Says Thank You to biggles For This Useful Post:
wood stove sharing a flue captainkid28 HVAC 5 01-04-2011 11:05 AM
Need help with chimney flue rwinsouthla HVAC 2 12-30-2010 01:44 AM
venting high efficiency flue gases kraigj3 HVAC 4 10-12-2010 12:49 PM
Flue Gas Piping and Proper Drafting DK75 General DIY Discussions 2 01-12-2006 09:04 AM
