Old 06-30-2011, 03:34 PM   #1
Flu pipes and insulation
Per my understanding, double wall pipe from the ceiling line all the way through the attic and out is code? Can I assume it is then safe to blow cellulose insulation right up against the pipe in that case? I have an 80% furnace and demand HWH (separate flues of course) and just get a little nervous about that I guess.
viper is offline   Reply With Quote
Old 06-30-2011, 07:00 PM   #2
You'll need to check the pipe manufacturer For sure but I would guess you will still need 1" or 2" clearance from any combustibles.
josall is offline   Reply With Quote
Old 06-30-2011, 07:13 PM   #3
How is that typically done in new homes? Do they use a triple wall or something or slip a larger single wall pipe around as a sleeve before filling with insulation?
Old 06-30-2011, 07:58 PM   #4
This may explain it better, http://www.northlineexpress.com/Imag...structions.pdf
Its called an attic insulation sheild.
Steam Pipe insulation. Any gain for insulating return pipes? slowjo HVAC 17 02-19-2012 09:53 AM
Water pipes behind basement insulation ariapn Remodeling 6 04-02-2010 10:28 PM
freezing pipes / bad insulation plumber red Plumbing 10 01-30-2010 06:46 PM
insulating heated garage(retrofit)- insul. & pipes KatieAK Building & Construction 0 10-25-2009 10:03 PM
Insulation around water pipes secutanudu Building & Construction 3 10-06-2009 09:32 AM
