-   -   Florida outside condenser unit iced over (photos) (http://www.diychatroom.com/f17/florida-outside-condenser-unit-iced-over-photos-61596/)
Carol2 01-11-2010 01:30 PM
I live in Jacksonville, Florida where the temps hit mid-20s for 10-12 hours last night. This is how my outside condenser unit looks this morning - all that white is solid ice. I have turned off my heat completely. The temperature is expected to go into the 50s today but another hard freeze is forecast for tonight. I can easily get by without turning on the heat overnight.
I did not have any sprinklers on last night and we have not had any rain for a week here in Jacksonville. So there was no water on it from either of those.
I know there should not be all (any!) of those shrubs around the unit, (the former owner planted those). They are actually not as close as they appear in the photos. They will be removed this spring. Could the moisture from the plants have caused this?
So what is the problem and what is the fix? The unit is about 12 years old but it has never given me any trouble. I have had it serviced regularly.
I plan to scrape and paint the grille in the spring, also (after removed from the condenser - will not paint while attached), to freshen the appearance.
Thanks so much for your help and advice!! Photos below.
Carol
How it looks this morning:
http://i20.photobucket.com/albums/b2...r/100_1334.jpg
How it normally looks:
http://i20.photobucket.com/albums/b2...0907Medium.jpg
H. Phillips 01-11-2010 01:46 PM
I can't see the photo's but when the outside is below 50 degrees or so the coil will ice up. A heat pump cannot pick up heat to pump into the house unless the coil is below the outside temperature and it should be about 20 degrees below. The ice will remain untill it blocks up enough airflow and then it will defrost and melt the ice. Still much of it may remain aound the housing as this will also be chiled by the nearby coil.
sktn77a 01-11-2010 03:11 PM
Doesn't your system have a defrost cycle? If it does, it wouldn't appear to be working. Maybe it's time to call an HVAC company.
The ice is coming from the humid air down there in Fl. At certain temps (cold enough to require heat but not so cold that the air can't hold humidity) you will get ice forming on the coils. That's what the defrost cycle is for.
Keith
beenthere 01-11-2010 04:16 PM
Yeah. Looks like a defrost problem. or a dirty air filter causing the defrost cycle to terminate too soon.
Could also be low on refrigerant. that will cause it to freeze up, and the defrost cycle will terminate before it can thaw the ice.
H. Phillips 01-12-2010 01:26 AM
Now that I see it, that is way too much ice. Either it is not initiating the defrost cycle, or it is low on freon. I don't see any partially melted ice or water that has run down the side so I suspect a bad relay or timer.
kennzz05 01-12-2010 01:30 AM
leave it running set on normal heat if it melts you just happened to shut it off before a defrost cycle
also that looks more like frost than ice, if after leaving it run for awhile (several hours) you still see it than its time to call someone
i just looked closer and yea the inside shouldnt be iced like that time to make that call
H. Phillips 01-12-2010 08:21 AM
That's what the ice looks like when it accumulates on the coil unless it is raining. If it had a partial defrost, wouldn't there be some clear ice and water on and under the unit?
