Flooring Under Furnace - HVAC - DIY Chatroom Home Improvement Forum
Old 11-15-2012, 06:45 AM   #1
Rewards Points: 242
Flooring under furnace
I have a newer Bryant gas furnace in my basement. It was installed on a floor which is made up of older thick vinyl tile. When the furnace runs it ends up moving slightly on the floor, causing some of the runs to squeal.
I'd like to slide something under the furnace to keep it from moving. I thought about sliding a piece of carper underneath, but is it ok to have a furnace on carpet?
Lemkie is offline   Reply With Quote
Old 11-15-2012, 06:52 AM   #2
Rewards Points: 13,732
A cushoned rubber mat would make more since to me to use.
Less likly to move around or mold up.
Old 11-15-2012, 10:11 AM   #3
Roofmaster
Rewards Points: 2,210
Move???
Causing some of the runs to squeal??? What does that mean???
Is something out of balance? How does a furnace that is tied into ductwork move? (assuming it is tied into ductwork)
You need to fix the problem first, then a rubber mat makes sense.
Old 11-15-2012, 10:40 AM   #4
Rewards Points: 242
Yes the furnace is tied into duct work. From what I can tell it vibrates a little when it runs, causing it to slide on the floor. It doesn't move much, but enough to cause a squeak between the cold air return connection and the furnace.
I'm planning on renovating the room within the next year, I'd just like to do something temporary to stop the noise for now. Will putting a piece of carpet with a rubber base under it cause any kind of fire hazard. this is really my only concern at this point.
Old 11-15-2012, 10:42 AM   #5
I'm Your Huckleberry
Rewards Points: 2,270
Grainger should sell rubber pads for this. They are little maybe 2" x 2" pads. Get four and stick 'em in each corner.
Thanks.
Doc Holliday is offline   Reply With Quote
Old 11-15-2012, 10:43 AM   #6
Rewards Points: 242
This will work as well. Again I just want to ensure this doesn't cause a fire hazard in any way.
Old 11-15-2012, 10:43 AM   #7
Thanks.
Old 11-15-2012, 10:44 AM   #8
Well it's an upflow so the heat is up on top of the furnace and blowing up so I doubt carpet would cause an issue but I still wouldn't use that. Those pads are meant for exactly this reason. Vibration isolation pads (dampers) are their true name.
Thanks.
Old 11-15-2012, 11:44 AM   #9
Rewards Points: 242
I will look into those. Thank you for that. Are they very thick? I can't move the furnace up too much because of all the gas pipes and duct so I'm really looking for something as thin as possible
Old 11-15-2012, 12:43 PM   #10
Roofmaster
squeek
I have seen flexible connectors which attach to your duct work with regular duct drives. They are like the accordion on an old time camera. If the squeaking is coming from the top of the plenum where it joins the main supply duct, this is what you will need. It really sounds like you are getting an unusual amount of vibration though to get squeaking. You may get some relief by injecting clear neutral cure silicone wherever metal is rubbing against metal. Tool it with a spatula, and turn off the furnace till it sets up.
Doc or one of the other pros may be able to tell you where to get the flexible connector.
Old 11-15-2012, 12:49 PM   #11
Roofmaster
Sorry
Sorry,
I said plenum, didnt notice return, but same thing applies, isolation. BTW if you want really thin rubber, go see a single ply roofer in your area and ask him for a small piece of 60 mil EPDM.
Old 11-15-2012, 01:36 PM   #12
Rewards Points: 242
I went to home depot and got some rubber pads that go under furniture. I put two of them under the furnace and it seems to have solved the problem. Way easier than trying to slide a carpet under the entire furnace. Thanks for the tips everyone!
Moving furnace & redoing ducting cbrc5eric HVAC 0 02-09-2012 08:13 AM
Propane Furnace - Diminishing Gas Supply After Ignition edro HVAC 9 01-13-2012 04:24 PM
Furnace running proper? Spydey HVAC 6 12-16-2011 07:57 PM
Problem with Lennox Pulse Furnace Wiring to Thermostat scalvin Electrical 4 12-30-2009 07:48 PM
Installing engineered flooring in the Philippines Flt_Simulation Flooring 15 07-21-2009 08:00 PM
