In Floor Heat Problems - HVAC - DIY Chatroom Home Improvement Forum
Old 02-19-2014, 11:18 AM   #1
In floor heat problems
My system is not working in all rooms...the kitchen floor and living room are warm, but the back bedrooms and bathroom floors are cold. I had a guy out the fixed the furnace when it wouldn't work, but this problem persists. Is it a bad valve or something else. Thanks so much
jimpap is offline   Reply With Quote
Old 02-19-2014, 11:49 AM   #2
Rewards Points: 1,284
Check the valves position. If ball valves, sometimes they have a mind of their own and change position without permission.
Old 02-19-2014, 12:37 PM   #3
Rewards Points: 808
Are the non working rooms on a different zone? Are there zone valves? Do you have a furnace or a boiler?
IslandGuy is offline   Reply With Quote
Old 02-19-2014, 12:43 PM   #4
I think it is a boiler and it only seems to have two valves and one of the seems to stick, but both are in the open position but no heating
Old 02-19-2014, 01:09 PM   #5
An old Tradesmen
Rewards Points: 7,372
May be air bound.
Hot water problems - not sure what's causing it ngk Plumbing 6 03-29-2013 06:42 PM
Drywall problems in new house BettyCv Building & Construction 39 05-28-2010 01:51 PM
Owen or Certain Teed has less problems?? reeses Roofing/Siding 10 02-07-2009 08:35 PM
Determining whether or not you have foundation problems? rmartin1286 Building & Construction 8 01-23-2009 08:09 AM
Are you having ice problems? Grumpy Roofing/Siding 27 02-17-2008 03:51 PM
