In Floor Heat Flow Adjustment - HVAC - DIY Chatroom Home Improvement Forum
Old 01-02-2010, 11:39 PM   #1
Hello,
Is there a correct way adjust the water flow in my in floor heat system for best efficiency? I have 2 loops (about 200' each, pex tubing) connected to one pump. There is a manifold where the tubes return with 2 valves on it that control water speed?
Always wondered what the most efficient "flow" is. Let the water flow quickly or slowly?
This is heated by a electric on demand boiler and the temp maxes out at about 110 F
Also what pressure should I be running in the system? Right now it's at 40 psi
Thanks,
Dustin
RoundPorch is offline   Reply With Quote
Old 01-03-2010, 07:56 AM   #2
An old Tradesmen
Rewards Points: 7,372
GPM requirement is determined by the heat load of the loop/zone.
Need to know that, with entering water temp(which you said is 110) then determine proper temp delta of the returning water.
This should have been done during the design process.
Little to no reason to run 40PSIG in the loops. Unless they are 80 foot or so above your boiler.
Old 01-03-2010, 02:11 PM   #3
Good to know on psi, the loops are only slightly elevated above the boiler, like 1 foot. I'll drop the pressure in there.
There was no design on this system. Was a 1890's house I remodeled and put concrete in for main floor. I installed the pex myself and had plumber add the boiler. The main reason was to make sure the floor doesn't get too cold in winter but it ended up being primary heat source with gas forced air furnace as back up.
Not sure if you can determine anything with that info. The house is about 1500 sq ft total
Old 01-03-2010, 02:55 PM   #4
An old Tradesmen
Yeah. Hard to tell you anything from that.
Check your loop temp difference. If its greater then 20, you can increase your flow rate.
If its less then 10, your a bit too high in flow rate.
Check your boiler to see how high of a pressure relief valve is on it.
low domestic hot water flow with tankless coil mike42 HVAC 28 11-24-2011 08:35 AM
Goodman air handler adjustment Xander08 HVAC 2 12-24-2009 02:32 PM
Hot water faucet pipe thumps then flow slows down. DIY-Indy Plumbing 9 07-15-2009 11:09 PM
very low shower head flow rickard681 Plumbing 7 10-08-2008 06:43 AM
Will rebuilding a vintage facuet make it low flow now? twilightcall Plumbing 1 06-14-2008 12:24 PM
